center speaker
Just bought some RTi70's and I have a CS300 center channel speaker. Since one of my old S-10"s is kind of shot I wondered if I might get better sound by using one S-10 as a center channel and if I can lay it on its side in front of my 54"TV. Crazy idea? or could it work???? seems the bigger range and size of the S-10 would be terrific. Any thoughts??
Post edited by orisfoto on
Since you have the CS300, try both centers and use the one that sounds best to you.
Maurice -
that is a good idea. i seccond that. but if you find some cash and want a real stealer center get a cs40i this is one heck of a center!
how do you do. I was monitoring the dialog.hope you don't mind my question. how would the cs400 compare to the newer csi40. I still see them for sale now and then at a good price.
the 400 and the 40 is allmost the same just different tweeter and the 40 is slimer and dont have the baffel on it.
Thabnks for the replies lads! Went ahead and laid teh S-10 on it's side on a soft baffle on the floor in ffront of my 54"screen and brought up my fornt speakers a little
the sounds is great
I can understand the dialogue pefectly!!!! Great sounds for a center speaker!!!
