Warranty for speakers bought off ebay
polkieintx
I bought a brand-new center channel speaker off ebay, from an unauthorized seller. I guess this means that I don't qualify for the 5 yr manufacturer warranty from Polk. So, what other options do I have for purchasing warranty? Are there any third-party warranty companies that have good feedback from the forum members? Thanks.
Post edited by polkieintx on
Squaretrade, NEW, Warrantech....
polkieintx wrote: »I bought a brand-new center channel speaker off ebay, from an unauthorized seller. I guess this means that I don't qualify for the 5 yr manufacturer warranty from Polk. So, what other options do I have for purchasing warranty? Are there any third-party warranty companies that have good feedback from the forum members? Thanks.
No is all I have. If you were worried about a warranty you should have bought one from a dealer. More then likely you will have no problems with a speaker unless you get stupid and crank it with some bad distorted power. -
Thanks, educatedink. I've heard of squaretrade but not too familiar with them. In any case, that looks like the best option as of now.
dave, the price was too good to pass up which is why I went with ebay... but, yeah, I know these are made to last, but just wanted to cover myself, just in case. -
I wouldn't worry about it, unless you abuse the speaker, I'm sure it will last a LONG TIME. Otherwise you can always buy replacement drivers, etc from Polk.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors**
