Best 2-3 ch Amp for the buck for RTi10's?
Hey guys,
I may be looking into getting a pair of RTi10's instead of RTi8's. However, I know that they require a lot more power to drive them. What's a decent amp I could get for them (best bang for the buck)? I'm running an Onkyo SR705 right now and at 100W/ch, will it be enough if I run them in 2.1 or 3.1?
Thanks.
Thanks.
Fronts: Energy RC-70
Center: Energy RC-LCR
Surrounds: Energy Veritas 1.0CM
Subwoofer: SVS PC12-NSD
Receiver: Onkyo TX-SR705
Amplifier: Denon POA-2200 w/ Ben's ICs
Pics of my setup (click me)
Post edited by Menasor on
Adcom 545II. One of the best bang for buck amp out there. Can be had for $150- $225
What it be sufficient though, to say run these guys on a 80hz crossover and let my sub take over for frequencies below? I feel like I'm wasting the speakers and might as well have RTi8's though.
Let me take a look at the Adcom 545II. Thanks as usual leroy
Pics of my setup (click me) -
Emotiva XPA-2.... Massive amounts of power, great amp. $799. Or the XPA-5, not quite as much power, but will run all of your speakers if you do a 5.1 system. Or the Emotiva UPA-7, seven channels, great amp, only $599 I think...
So, check out Emotiva."People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." George Orwell -
Hm, before I dive into anything, I remember I still have an old Denon amplifier lying around that my Grandpa gave us in the early 90's. I think it's two channel. Let me take some pics and see if any of you guys can figure out what it is.
Any reason why I shouldn't be using an old amp?
Nope....take some pics and we'll go from thereLiving Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
OK, so no pics yet, but I got the model numbers from my dad. Also have a pre-amp as well.
Pre-amp is Denon PRA1200
Amp is Denon POA2200
I read somewhere that the POA2200 is 200W per channel? Will the Pre-amp do me any good? Thanks!
You don't need the pre amp. You can use the Onkyo as your pre amp.
FYI: Recent eBay auction for the pre, $150.
http://cgi.ebay.com/DENON-PRA-1200-PREAMP-PRA1200-PREAMPLIFIER_W0QQitemZ120310508652QQcmdZViewItem?hash=item120310508652&_trkparms=72%3A1205|39%3A1|66%3A2|65%3A12|240%3A1318&_trksid=p3286.c0.m14Alea jacta est! -
Thanks guys. Maybe we'll sell that pre-amp.
Is the 200wpc from the POA-2200 going to be a good amount for the RTi10's?
200 watts is more than enough and will make those babies scream( in a good way).
should I just plug the csi5 directly into the onkyo when I get it? Or should I get a single channel amp?
Try it with the Onkyo first. You may be happy with the sound.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
Definitely will do.
What cables would you guys recommend using to connect the Onkyo SR705 to the POA-2200?
... What cables would you guys recommend using to connect the Onkyo SR705 to the POA-2200?
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021803&p_id=2869&seq=1&format=2
http://bluejeanscable.com/store/audio/index.htm
http://signalcable.com/analog_interconnects.html
http://shop.bwaudio.net/index.php and http://www.polkaudio.com/forums/showthread.php?t=71890Alea jacta est! -
Get Ben's ICs...you're done.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Wow such a price difference between Monoprice cables and others. No doubt the others are really good. How do the Monoprice cables compare at 1/10 the cost?
Wow such a price difference between Monoprice cables and others. No doubt the others are really good. How do the Monoprice cables compare at 1/10 the cost?Alea jacta est!
I'm surprised John K hasn't jumped in yet.Personally,for IC's, I'd go with Ben's then Signal then Blue Jeans. I've owned all three and that is the order in which I would get them. -
IMO I would take the 8's if you're using sub. Amp you already have although I'm sure you're AVR would be fine too (but no harm done in trying the external amp). -
Unfortunately the place I ordered the RTi8's at ran out of stock and are upgrading me to the RTi10's for free. I had bought the sub thinking that I would need it since I was planning on having 8's. The sub should still outperform the RTi10's in terms of bass though so that should be ok.
The added amp should improve hi's and mid's as well (in addition to bass) for the RTi10's right?
Yes, the by adding a amp it will improve your mids and bass for the rti 10's.
