need help selecting surround speakers
I have RTiA5 fronts, CSia4 center, and a dsw600 sub. I need surrounds...it says that teh RTiA5s are "timbre matched" to all other polk speakers. Obviously, it would be best to use the FXiA4 surrounds but i'm thinking my wife will think they are too big. I will have to use stands for the surrounds so I was thinking the RM8s with the sleek glass bottom stands would look best.
Would they sound good or are FXiA4s much preferred?
Post edited by rxtasy on
Personally, I would go with the FXiA4 with your current setup.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
I too have have RTi A5s as front, CSi3 as center and PSW110 sub. I am planning to go for 7.1 setups. I am also debating whether to go for RM101 Satellite Speaker or FXi A4 for surround rears and sides. I am more worried about sound quality to match A5s and CSi3. Price difference is huge between these two sets. I can get four RM101s for $225 where as four FXi A4s are costing $800.
Appreciate any input on which ones to pick. -
I recently picked up the FXi A4's and have been extremely happy with them. I think they would compliment your existing set-up very well.My Set-Up:
Sharp LC60E88UN- Display
Yamaha RX-A2020- A/V Receiver
Pioneer Elite BDP-23FD Bluray Player
Toshiba HD-A2 HD-DVD Player
Velodyne DPS-12 - Sub
Polk RTi8's- Fronts
Polk CSi5 - Center Channel
Polk FXi A4's- rear surrounds
Monster HTS2600 Line Conditioner
PS4 -
I am looking for both surround sides and surround rears. If I take four FXiA4s, are the worth $575 more?
You can get a good deal on some fxi a4 from Polk Direct . This will be a good choice for surrounds and rears. Also RTI A1's will work good as well for less $.
I agree with leroyjr, I picked up my FXi A4's on Polk Direct and they were absolutely mint. After shipping and tax, I paid roughly $270.00 a pair. IMO they were worth every penny.My Set-Up:
Polk RTi8's- Fronts
PS4 -
Thank you all. I'll see if I can get that kind of deal
Picked up FXi A4s from Polk Direct on eBay (refurbished) for $250 including shipping. Hooked them up and they sound great.
Congrats and enjoy them! They are really great surround speakers.My Set-Up:
Polk RTi8's- Fronts
PS4 -
Thanks for the advice. I went with the FXiA4s as advised. I have yet to hook them up because I need stands to hold them.
I should have done a bit more research beforehand but I have been researching a bit more since I have received them. Much of the advice on the web indicates that direct surround speakers are much preferred....is this true? Did i make a mistake?
From the way the room is setup i will probably be using the bipole mode. According to advice on the web most movie/music is designed for the direct surround sound speakers.
Any thoughts? If you need any more specifics about my room characteristics please let me know. Thanks. -
My advice is to relax...when you are able to get em hooked up I think you will be very happy with them. I don't have any buyers remorse at all, they are excellent surround speakers. Once you get them set-up, you can experiment with di-pole and bi-pole settings until you get something your happy with. In terms of direct surround speakers being "much preferred", that's totally personal, let your ears decide.:DMy Set-Up:
Polk RTi8's- Fronts
PS4 -
I wouldn't sweat it - I think you're going to love them!!
What does your room look like? Dimensions, etcLiving Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
I Love my FXI3's (surrounds) and for my 7.2 set up is used RTI4's for the rears. I was almost going to get 4 FXI'3 but they guy at polk talked my into RTI4'3 for the rears.Audio:
Onkyo :tx-sr805
Polk: rti8's
Polk: rti4's
Polk: fxi3's
Polk: csi'3
Velodyne: VRP 1200
Epik: Caliber
Video:
Panasonic:TH-42PX60U 42"Plasma
Power Conditioner:
Monster Power: HTS 3600 MKII Home Theater
Dvd:
Sony: BDP-350
Game Systems
WII
PS3 -
Here are a couple of pics of the room. It is a a great room, kitchen, and dining room open floor plan...very high ceilings in both great room and kitchen. We are in the process of looking for a sectional to surround the fireplace. I plan on putting the surrounds on the wall that separates the kitchen from the great room. Therefore, the front speakers are facing diagonally across the room while the surrounds will be facing straight toward the fireplace. I'm thinking the bipole feature may work out great for those circumstances.
Thanks again for the advice and hopefully the attached pics will help with more thoughts. -
bumping b/c of pics attached
