How to do
just follow the diagram on the speaker cabinet. I'm 99% sure the Rotel is common ground.
ET
System: MF Trivista SACD > Placette passive> CJ passive horizontal bi-amp> MF 2500A(LF) MF2100(HF) > 1.2TL's
Other: Speltz silver Eichmann IC's & speaker wire, Econotweaks Detail Magnifiers, PS Audio P-300(source), R. Gray 600, Al Sekala's AC R/C filters, R. Gray HT PC's, Oyaide R-1's,WPC-Z , M-1, Herbie's & DIY Isolation
Room: Qty 7 - 4' tall 18" diam. bass traps, Qty 4 - 4' X 2' X 4" panels. All DIY - man my wife is tolerant! -
Do you have a digital multimeter? That is the easiest way to determine common-ground on an amp.
YES I do. I will see whit meter if they are having open line or not. If they are open line then it is OK to do common ground on that amp ?. I know before I test I must take out the speakers wire. -
Use the continuity setting on your DMM and check the two negative binding posts. If they have continuity, you are in good shape and just hook-up the speakers like regular.
OK. If they do not have continuity then ok to put wire in that amp ?. Roy -
If they do not have continuity, you will have to ask the Rotel or someone who knows if tying the negative binding posts together will damage the amp.
Hi. I did the test last night on my amp and amp did have the continuinty in all four negative post. Do i need hook up my speaker SDA SRS 1.2TL to amp rotel RB-1090 like bi amp or just do like singel amp ?. Because I had hook up like bi amp before and it did not have good sound it all. It feel like hum in it. any thing moor to do ?.
