Problem Pioneer 1018 And PS3 Hookup
kgingras
kgingras Posts: 113
edited October 2008 in Electronics
I posted this over on AVS under the official Pioneer 1018 thread but it got buried.
I've had my PS3 hooked into the HDMI BD input and all was working fine. Now I get no audio and only video. I was playing around with some of the functions on the receiver and perhaps switched something I shouldn't have. The PS3 and HDMI cable are fine as they work when using the regular HDMI input. I’ve checked that the audio output on he PS3 is set to HDMI. When I use BD and hit the System Select, Multi Channel In blinks. Any ideas?
Thanks.
Pioneer VSX-1018
Emotiva XPA-2
Parasound 2100
Emotiva ERC-1
Music Hall MMF 5
Strata Minis
PS3
Samsung PNA50A550 Plasma
Post edited by kgingras on
  • Tollaksen
    Tollaksen Posts: 71
    edited October 2008
    kgingras wrote: »
    Thanks.
    Try another HDMI slot to see if it is infact the reciever or the Ps3.
    On my hk I can select the audio source for each video input. I am not sure about the Pioneer.
    Check all the setting in the PS3. At one point I did something to the settings. The best thing to do if you haven't already is to hold the power botton on the PS3 for 5 secs, this resets the PS3 and will defualt the video and audio to the lowest setting. Then it will reconize the HDMI and you can start over.
    Reciver Pre/Pro - H/K AVR-347
    Amplifier - Adcom-7400 5 Channel
    Speakers - SRT's
    Projector - Sony Avl-aw15
  • olilugo
    olilugo Posts: 405
    edited October 2008
    on the remote for the pionner press the receiver button and then the BD button. be carefull not to have your volume to high...
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    Sub: Velodyne DLS-3750R
    Receiver: Pioneer SC-07
    Amplifier: Sunfire TGA5200
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
    CDP: Pioneer DV-48AV
    Interconnect cables: SignalCable analog II
    speaker cables: SignalCable Ultra Speaker Cables Bi-wire
  • kgingras
    kgingras Posts: 113
    edited October 2008
    Hey guys,
    I have done just that. The HDMI cable and PS3 work just fine in both of the other 2 HDMI inputs.
    Pioneer VSX-1018
    Emotiva XPA-2
    Parasound 2100
    Emotiva ERC-1
    Music Hall MMF 5
    Strata Minis
    PS3
