FX300s question
I have the FX300 as my surrounds directly to the sides of the listening area. 5.1 setup. As I understand, the MidWoofer/Tweeter side of the speaker should face the front of the room.
I haven't tried it, but has anybody tried switching these two surrounds? Therefore having the MidWoofer/Tweeter side of the speaker facing the rear wall and the Tweeter only side facing the front of the room. How would this sound?
Post edited by tim_alag on
I have the same speakers in my 7.1 setup. I have not tried them the way you mention, however I am very pleased with the way they complement my system. For the money they are pretty good speakers.
marvelous
Thanks for the reply. When I get my 7.1, I will definitely face the MidWoofer/Tweeter foward. I just wonder what it sounds like with 5.1. I'm going to switch them around and see what happens.
Just curios what kind of speakers you have as your rears, center and fronts? -
I have them as well. I don't have them on the side walls but right behind me. They suggest setting them up so they fire away from the listening position. I did what you are thinking about and have them firing into the middle of the room and have found that I like the sound stage better this way.Pioneer Elite VSX-21TXH
Monolith 7x200 Amplifier
Harmony Hub
Sony VLP-HW40ES
Visualapex 106" Electric Screen
Oppo BDP-103
Music Hall MMF 2.1
Polk LSiM 705
Polk LSiM704c
Polk LSiM702F/X
SVS PB-2000 -
I have them on the side wall in front of my listening position and I
have them switched around so the main tweeter/ mid woofer face
me. This set up works for me. The way the room is set up this is the only way I could do it. I know it sounds funny but it really works. Watch something like "Windtalkers" and its frightening as hell. Try it see what you thinkJmasterJ Polk to the Death -
i have the 500 with is the same design as the 300 but with bigger woof and tweet. i have 4 of them all setup whe way polk recomend. try the bi/di switch that might help. and on the back wall if they are more than 6 feet apart polk says you shold put the left on the right and so forth and so on.
Nice web page Ganzo - I have been wanting to do one for quite a while now. Maybe this weekend.
soccerplyer how do you have your CSI30 Bi-wired?? Just curious as i had that one and it didn't have the capability to do so, was wondering if there was a different way to do thisMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
How do I bi-wire it, weeellllll..... i don't. Didn't realize I wrote that.Pioneer Elite VSX-21TXH
Harmony Hub
Sony VLP-HW40ES
Oppo BDP-103
Music Hall MMF 2.1
Polk LSiM 705
Polk LSiM704c
Polk LSiM702F/X
SVS PB-2000 -
thanks scott. it is free but the site bulder that is free dont come with that many optons. i need to over haul the site and get some new pics. i keep changeing things around alot. have my new sub project. trypod and geocities have free sites.
tim_alag
i have my fx300 on the side wall a few feet above my couch. they face inward as opposed to being on the rear wall.
The tweeter side faces the rear wall and bounces sound off it. i run mine in bi pole setting. becasue I only have a 5.1 system.. running them this way gives me great rear imaging. Whenever i run a test disc with rear surrounds test on it.. the fx300 sound great.. even though they are compasating for the lack of a rear center. i'm very happy with them.PolkFest 2012, who's going>?
