PS3 As Main CD Player?
kgingras
kgingras Posts: 113
edited October 2008 in 2 Channel Audio
How does everyone think the PS3 measures up for playing CD's against a run of the mill CD player? I've got an ealry 90's HK CD player that is pretty basic. Probably their low end player at the time. But I find I prefer the sound of the PS3 for CD's. Just seems to be more full to me.
Pioneer VSX-1018
Emotiva XPA-2
Parasound 2100
Emotiva ERC-1
Music Hall MMF 5
Strata Minis
PS3
Samsung PNA50A550 Plasma
Post edited by kgingras on
  • stebesplace
    stebesplace Posts: 57
    edited October 2008
    If it means one less device in your arsenal, and it sounds good to you, why not? I think it plays no different than any other "normal" cd player. I use my Samsung DVD player to play cd's and I think it sounds great to me. There are obviously better cd players on the market however, nothing wrong with using it to play cd's!
    Current Setup:
    :( Yamaha AX-450 Amplifier
    :) Yamaha YST-SW216 Sub
    :) Sony DVPNC800H/B CD/DVD Player
    :) Samsung LNT2653H LCD TV
    :)polkaudio R150's
  • lakesailor
    lakesailor Posts: 319
    edited October 2008
    Your PS3 will have a better onboard DAC than your older entrly level H/K will. The only downside to running the PS3 is that they are noisier (when running) and take a bit more time read discs than a dedicated CD player will. Also it can be a bit more challenging sometimes with the remote and changing tracks
  • kgingras
    kgingras Posts: 113
    edited October 2008
    Thanks for the advice. I'm short on space so will get rid of the HK. I've heard a lot of people complaining about the fan noise on the PS3's but I do not have that problem at all at least when playing a CD or a BD for that matter. Its a brand new one (80g) so perhaps some of those issues were fixed this time around. I also just ordered the Sony Bluetooth remote so hopefully that will be a much better interface then the game controller.
    Pioneer VSX-1018
    Emotiva XPA-2
    Parasound 2100
    Emotiva ERC-1
    Music Hall MMF 5
    Strata Minis
    PS3
  • broncsrule21@
    broncsrule21@ Posts: 113
    edited October 2008
    Yeah that remote is life saver if you are using your PS3 to play BD and CDs.
    HT-- Denon avr-2808ci,Emotiva UPA-1s, RTi 10's, CSi A6, ERD-1 surrounds, Vizio P50, Yamaha yst-sw300, DVR hr21, 40g PS3, APC-h15
    Downstairs-- Denon avr-3300,Emotiva UPA-2, Toshiba 50" rear projection, Denon 2200 sacd, Emotiva ERM-1s, small Yamaha sub
