Tweeter blown in 10B?
kgingras
kgingras Posts: 113
edited October 2008 in Vintage Speakers
Fuse is good but nothing coming out of one of the tweeters. Have tried various input sources (CD, PS3, DVD etc) but no sound. The 1 amp fuse is not blown. Can a tweeter fry even if the fuse does not blow? I guess I was pushing them a little further than I have before (new amp).
Pioneer VSX-1018
Emotiva XPA-2
Parasound 2100
Emotiva ERC-1
Music Hall MMF 5
Strata Minis
PS3
Samsung PNA50A550 Plasma
Post edited by kgingras on
  • george daniel
    george daniel Posts: 12,096
    edited October 2008
    swap the tweeter and see,or remove it and attach it to speaker wire,,and Carefully turn up the volume,,then you'll know--good luck.
  • kgingras
    kgingras Posts: 113
    edited October 2008
    Thanks George. I did the swap as you suggested and it does not work on the other side either. The good one does work. So I guess it is toast. Perhaps the fuse does not offer 100% protection?
    I'd order the RDO's but I understand that requires some modifications to the cabinet to fit? I found a pair of 7B's on CL for $75 - http://columbus.craigslist.org/ele/859324682.html. I'm wondering if I could just swap those tweeters for my SL1000's?
    Edited to add...I think it was Genesis' "Mama" that toasted this ****!
    Pioneer VSX-1018
    Emotiva XPA-2
    Parasound 2100
    Emotiva ERC-1
    Music Hall MMF 5
    Strata Minis
    PS3
  • jtgranby
    jtgranby Posts: 887
    edited October 2008
    kgingras wrote: »
    Those are not 7b's. They are Monitor 7's series 2 with SL2500 tweeters and will not work with your speakers. Good luck.
    Jim
  • kgingras
    kgingras Posts: 113
    edited October 2008
    Just ordered the RDO's yesterday. And I guess I'll be getting the Rotozip too.
    Pioneer VSX-1018
    Emotiva XPA-2
    Parasound 2100
    Emotiva ERC-1
    Music Hall MMF 5
    Strata Minis
    PS3
