better sub psw111 or 110
forgiven814
I am new to this game and need help with what sub to use in a 12x20 room with one doorway 6' wide looking for good clean deep bass:
upgrading receiver to onkyo
monitor 70's
cs2
monitor 40's
sony 12' powered sub
any suggestions would be awsome!
monitor 70's
cs2
monitor 40's
Post edited by forgiven814 on
The PSW 125 is a nice sounding 12 inch sub and can be had cheap.
I recently purchased the psw110 (to go with my tsi200s and my cs10) and I'm extremely happy with it. I tested the 110 and 111 side by side on multiple occasions at Best Buy and opted to go with the 110 because it seemed to produce deeper and louder bass than the 8" psw111. The 111 has 100 more watts, but when turned up very loud, the 110 still produced more bass to fill a room. My living room is 25x12 and I don't believe the smaller 111 would've given me enough kick. It puts out great sound for an 8" sub, but it's probably better suited for a smaller room.Mains - TSi200
Center - CS10
Surround - TSi100
Sub - PSW110
AVR - Yamaha RX-V663
Movies/Games - PS3
Music - iPod Nano
Satellite - DirecTV HD
TV - Panasonic 46PZ85U
PSN - mrSM1TTY -
Since you are pretty much putting together the exact same setup I have, I would recommend the PSW125 as leroy suggested. I got mine from CC for $250 (before warranty) and it is a great sub for the price. Which Onkyo receiver are you looking at? I just got the TX-SR806 and am blown away by what it does/is capable of doing for under $1,000.HT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
PSW110 would be better for your application. It is a little larger but has much more authoritative low bass response. This is one of the reasons we now provide the CEA2010 (Loud and Low) Spec for our subwoofers.
PSW110
Low 114.6 db
Ultra 86.7 db
PSW111
Low 115.5 db
Ultra 75.4 db
PSW125 is even better:
Low 118 db
Ultra 90.5 db-Eric
-Polk Audio -
Thanks for all the advice it has been rellay good and i will be going with the psw110
hey wuatdumsn23 does the 110 sound boomey .... i am going to have to put it in a corner and was wondering if you are using it this way.....
Hope i dont get in trouble for this because I love my polks but you might check into bic h100 you can get it for 229 shipped and it goes down to 24hz compared to the psw 110 that goes down to 38 hz.Polk Tsi 500 Fronts
Cs20 Center
Tsi 100 sides
Rti a5 rears
Bic h100 subwoofer
Ps3 40gig
Onkyo 805!
Sony Kds55a2020 rptv -
Guess I will get into trouble with you. Many choices and many opinions on whats good. I am running 2 Outlaw EX's with 12" woofers, 350 watts each, and they get down to 16 hz. No matter which one you choose it will be a improvement and put a big smile on your face when you get the first real kick from it.
