Equalizers
PolkClyde
I hope I'm asking this question under the right thread anyway Here's my question: what do you guys think/opinion on Home Audio Equalizers. I like them. I'm not using one at the moment but I thought about buying that 12 or 15 Band Equalizer from Radio Shack. What Equalizer do you guys Recommend with the less noise. or should I buy one off the Used Market.
PC
PC
PolkAudioClyde
Post edited by PolkClyde on
The purists don't like tone controls of any kind. Unless you have "golden ears" you won't hear any difference having an eq in the audio chain if you bypass the eq controls. That leaves you some control to tailor the music to your liking beyond just using the basic treble and bass features on some gear.
I own 5 eq's....I don't use them all. But I wouldn't buy one from Radio Shack though. There are plenty of excellent used ones out there that can be had at a good price which were at one time "mouth watering" pieces of equipment.
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
None."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
EQ's are very useful for taming frequency peaks in a room, but can introduce noise. (don't boost the nulls) IMO, the proper use of EQ involves cutting frequencies, rather than boosting. Less is always better. Very few, if any system, or room is so perfect, that it couldn't benefit from EQ in some form.
Use the AEQ settings in your AVR and save yourself some coin if you must use one. I personally turn it off.Shoot the jumper.....................BALLIN.............!!!!!
LessisNevermore wrote: »EQ's are very useful for taming frequency peaks in a roomTesting
Testing
Testing -
Eq's are for fixing something wrong with the room or your equipment
eqs can often result in phasing, the more bands you have the more phased the output will be???ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
I think EQ is find for subwoofers, but I don't use any for my main speakers. What's the point of buying different speakers, then EQing them so they all sound the same?
