Yes, another evaluate my setup thread. :)
RichterCAG
hi
Please rate/evaluate my setup.
The components :
RTi10 x 2
CSi5
Atrium 45 x 4
All driven by a H/K AVR330.
Also, might someone sugest good crossover frequincies for my setup?
The components :
RTi10 x 2
CSi5
Atrium 45 x 4
JVC 61FN97
Harman Kardon avr330
RTi10 l/r front
CSi5 center
Atrium 45 (four for the surrounds.)
RTi10 l/r front
CSi5 center
Post edited by RichterCAG on
Very nice setup. Pics?
If you're looking for more, you can always get an amp for those RTi10's:DLiving Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
Interesting choice of surrounds ... The Atrium surrounds, usually used for outdoor applications.
I got to love Polk's description of the Atrium's 'Uncle Sam WANTS you to have some Atrium speakers' ... LOL
http://www.polkaudio.com/homeaudio/products/multiapplication/products/atrium45/
Sticking to the same series, for example RTi series, yields the best sound blending. The Atrium probably sound nice however might not blend quite as well as RTi4s, which I have seen on sale for $129-149 CAD lately, with your Rti10s. They go deeper as well in the frequency range 50hz compared to the 75hz of the Atriums. You would get some more depth of sound in your surround soundtrack. If you ever upgrade the surrounds you can always move the Atriums outside! for some sweet music on the patio or backyard which is more than most speakers can do when taken out of the main rig. Most speakers end up going in a box in the basement while the Atriums can go anywhere if space is limiting inside.
Enjoy your setup.
Zsolt -
RichterCAG wrote: »hi
The components :
RTi10 x 2
CSi5
Atrium 45 x 4
How does it sound? -
Q. Very nice setup. Pics?
A. no pictures just now. But I could easily post some.
Q. How does it sound?
A. Great! The depth is not as present as the RTi line however. That is to be expected. Even so, these four Atrium 45 seem to pair well with RTi10 in tone. Prior to these 45's, I had two R50 series and two Atrium 45 installed as surrounds. There is a marked improvement from switching to matching rears.
Q. Are you using a subwoofer with this?
A. No. I do have a subwoofer from Polk. Although the subwoofer is not in use.
Spacing and mounting placement is at a premium in my listening area. The small size of the speaker in comobation with the swivel mount bracket is what really makes this particular speaker so ideal for my room layout.
As an aside, some of you might be interested to know that not one of my speaker wires is dropped on the floor or tappered across the walls. Fact about it : all of the wires, except for the fronts and center, are rouoted up though the celings though gang boxes and conduit. The gang boxes are fitted with banana plug faceplates. :cool:JVC 61FN97
RTi10 l/r front
CSi5 center
Atrium 45 (four for the surrounds.) -
With no sub, I would set mains and center to large, rears to small with 100hz or 120hz crossover.
Try some other crossover settings to see what you like, but my starting point would be 120hz with a trial of one click above and below that setting to see if I like it any better.
Enjoy the system,
Why don't you use the sub?
JVC 61FN97
RTi10 l/r front
CSi5 center
I bet that sounds real good for movies!!
If you wanted more out of your 2-channel, you could look to add an amp as I stated before.
If/when you look at subs, don't think you have to match to Polk.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
Yes, it does sound nice. Depending on the movie of course.
As for crossover, I should set the rears to 120hz and the fronts to 40hz?
My reciever is a h/k avr330. Yep, a harmon kardon. Betcha never would have guessed that, huh?
:rolleyes: JVC 61FN97
RTi10 l/r front
CSi5 center
Rears 120hz. Set the fronts to no crossover or large. (I would set the center to large as well, but you could cross it over at like 60hz if you wanted to....)Mains.............Polk LSi15 (Cherry)
