Looking for some help on upgrading
rdb2001
rdb2001 Posts: 791
edited September 2008 in Speakers
I want to upgrade my system. I want to buy a good set of floorstanders and need to know what would be a good pair to go with. I have a 5.1 system(check out rdb2001 on system showcase). I want to move my front bookshelfs to the surrounds and add the floorstanders to the front to make a 7.1. I am also looking for a new receiver that with decode true hd. Thinking about going with something from marantz, but I like my yamaha and thinking about using one of their higher end receivers. Cant wait for your input.
Post edited by rdb2001 on
  • leroyjr1
    leroyjr1 Posts: 8,785
    What' s your budget? You don' t have to get a receiver that decodes if your Blu ray player does. Just a thought.
  • rdb2001
    rdb2001 Posts: 791
    my budget is about 600 for the pair of floorstanders. I have a ps3 for my blu ray playing. When I play bluerays, my receiver says PCM. I thought to decode dd true hd and dts hd you would need a reciever that decodes that. Mines only has 1080p pass through.
  • leroyjr1
    If it were me I would try to match everything. Do you have to have floorstanding speakers because for $600 you can get rti a3 for the front and surrounds and csi a4 for the center for $600 and it will be a improvement over your current setup. Or you could just grab a pair of rti 10's or 8' s for the fronts. But it will not match your center.
  • rdb2001
    rdb2001 Posts: 791
    Where would I find those speakers at for those prices. On polk they list for 500 a pair for just the rti a3 alone. So I do not know how I would by 2 pair and a center channel for six hundred. But if you can show me where that is, I am definitely going to get them. I have found a good deal on a 7.1 THX certified Marantz receiver. It is refurbished though with a one year warranty. I am also looking at an 800 series yamaha. Your thoughts.
  • Ron Temple
    Ron Temple Posts: 3,212
    Keep checking at the Polk Direct store on ebay. Right now there are no A3s or A5s, but last week there were several pair. Theres a CSi A4 or two and an A6 awaiting bids now.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
