Hi guys newbie here need help
pinoytoits
pinoytoits Posts: 2
edited September 2008 in Speakers
I have polk audio rm7500 and Onkyo 705 and a infinity subwoofer when I run the audessey the onkyo reports my sat speakers as full band is that okey or should I set it manually by 80hz (small) need help, and should I set my subwoofer crossover to the max and level the volume over sub at half point? before I run the audessey? thanks
Post edited by pinoytoits on
  • ben62670
    ben62670 Posts: 15,969
    Hi and welcome to club Polk. The 7500 series would be fine to set at 80hz:) You may try 60hz, but your receiver would have more load on it. set the sub at 80, or 60 to match.
    Ben
    Ben
  • pinoytoits
    pinoytoits Posts: 2
    Thanks! I will try that.....I appreciate it very much.
