Opera Consonance DAC16 - Help Pricing
SolidSqual
SolidSqual Posts: 5,218
edited November 2008 in Electronics
Hey,
I recently acquired the DAC16 below. I'm going to compare it to the MHDT Havana I just purchased. If it loses then I'm going to sell it. Anybody know what a fair price would be? Anybody know what I can expect from this DAC?
Consonance now offers their new DAC16, a 16-bit digital analog converter that uses the TDA1543 plus offers both USB and SPDIF input. According to the company, "SpAct memory architecture and Linear technology have been applied in the whole USB and built-in DAC section, where the received digital signal from computer is checked, clock corrected and decoded through. SpAct memory architecture is set within the data path establishing smoother data flow so that the final audio has the lowest possible jitter. It ensured that the built-in DAC section set latter is able to be fed with information both higher data integrity and lower jitter." The same technology is found within Consonance's CD120 linear CD-player. RCA input and output terminals are gold-plated RCA, while a USB input handles streaming audio data from a computer. DAC resolution is 16-bit using the TDA1543, while maximum output is a healthy 2.35 Volts. Frequency response is from 20Hz to 20kHz with a phase accuracy of less than 5 degrees deviation. Signal-to-noise and crosstalk is a low 100dB while distortion via RCA output is less than 0.12 percent. Enjoy the Music.com has reviews various Consonance-Opera products including the Consonance Cyber 211 monoblock amplifier (click here), Opera Audio Droplet LP5.0 turntable (click here) and the Consonance Cyber 10 Multifunctional tube amplifier (click here).
http://www.opera-consonance.com/products/DAC16.htm
Post edited by SolidSqual on
  • Angaria
    Angaria Posts: 1
    I've got an Opera amp I like, might give one of their dacs a try. Shoot me a PM since I'm new here. Feedback on audiogon, same username.
  • dorokusai
    dorokusai Posts: 25,576
    I like Consonance gear and have been a fan for a few years. I believe I picked up my first piece from Stephen up north when he started carrying the line.
  • SolidSqual
    I sold this a month or so ago.
  • sucks2beme
    sucks2beme Posts: 5,684
    So, how did it sound?
  • SolidSqual
    Sounds fine. Overpriced for what you get at retail. I got it for $300. Even at $300 there are better like the new Cambridge Audio DAC. Does nothing special.
