SDA 1 Price question
HB27
HB27 Posts: 1,518
edited September 2008 in Vintage Speakers
I found a pair of SDA 1s Locally for $500. Look to be in great shape. NO cable.
Is this a good price for the 1's?
Thanks,
Harry
Post edited by HB27 on
  • Ricardo
    Ricardo Posts: 10,634
    Which 1's? In any case, it seems a bit high, specially if the interconnect is not included. Of course being local is a plus.
    SOPA
  • HB27
    HB27 Posts: 1,518
    Pics of them. Sorry, I'm not used to the format on some of the buttons.
    hb
    heiney9 Posts: 25,487
    Those are very early 1's and $500 is too much. Even if they are minty. Later 1's like the "C" are much better sounding since they were among the last generation's. The "C" had better x-over's, drivers, eliminated the dimensional tweeter, better cabinets, etc.
    Those 1's would be nice for $200-250 (if minty) but then you'd just want to upgrade to a newer generation eventually. The later generations are really much better sounding.
    YMMV
  • Ricardo
    The older with the SDA tweeter. I would not pay half of what they are asking.
    SOPA
  • HB27
    HB27 Posts: 1,518
    Thank you. I appreciate it.
    Harry
  • IrishNiner
    IrishNiner Posts: 116
    HB27,
    The $200 to $250 estimate is about right. I bought mine for $200 in mint condition with the interconnect. Then upgraded to RDO 194's. They sound very good but not great. The dimensional tweeter takes a little getting used to.
    Farrell
  • ben62670
    ben62670 Posts: 15,969
    IrishNiner wrote: »
    HB27,
    Farrell
    It's very easy to disable the dimensional tweeter. I have helped a few with the mod. To trial run the mod just pull the fuses on the dim tweeters, or disconnect one of the leads. The highs will be slightly attenuated, but the mod just consist of reducing the resistance of the stereo tweeter.
    Ben
    Ben
  • IrishNiner
    Thanks Ben,
    I'll try pulling the fuses later today and maybe turning up the treble a little to compensate. The holographic nature of the highs had me considering selling them, so hopefully this will help.
    Farrell
  • HB27
    HB27 Posts: 1,518
    This guy also has a pair of the newer ones with different tweeter placement. he's not sure of the model so I'm going to wait for his pics this afternoon. He has a pair of cables made for them. they are Pin Blades.
    I'll figure out the model on them and get more "pro" advice before spending the bucks.
    Thanks again and I'll keep you posted on progress. I'm REALLY wanting some nice SDA's.
    Harry
  • NJPOLKER
    NJPOLKER Posts: 3,475
    Hey Harry,
    Your doing the correct thing by waiting for the "right" SDA's to come along and I am sure it will pay off.
    I could not tell from the picture of the back of the SDA's in the picture, do you know if these are SDA's with that different cable, not blade/blade and not pin/blade but some other contraption? If so you may really really want to pass on them.
    Drew
  • danger boy
    danger boy Posts: 15,722
    $500 :eek: :confused: :eek:
    he's never gonna sell them at that price.
    PolkFest 2012, who's going>?
  • NJPOLKER
    danger boy wrote: »
    I agree with you and not looking to dispute that they are over priced BUT, :rolleyes: Is there a pair of speakers, other than other SDA's that sound as good as these for $500.? I myself do not know but am curious what the thoughts are. Hell I pair $500 as I remember for a pair of mint condition SRSII's.
    Carlos, if you read this thanks again I am keeping them in great condition.
    Drew
  • gdb
    gdb Posts: 6,012
    I bought some SDA1s off ebay that were close by, so I was able to pick them up, this was before I knew anything about all the different versions made. I gave $267.00 IIRC they have real walnut veneer but they also have SL2000 tweeters which I don't too much care for. Those look like they may have Peerless tweeters,which I like a lot, on my Mon10s. They're still Polk SDAs, and can be modded and upgraded(not by me however:() If you can get em cheap,do it ! I just bought some SRSIIs, but still plan to keep the 1As and get the XOs re-done and drop down to one RDO tweeter per side.Good luck ! gdb:)
  • Face
    Face Posts: 14,340
    NJPOLKER wrote: »
    Drew
    For $500, you'll be hard pressed to find a comparable full range tower.
    gdb wrote: »
    They are sl1000 tweets, as bad or worse than the sl2000. Not peerless tweets
  • HB27
    HB27 Posts: 1,518
    NJPOLKER wrote: »
    Drew
    I'm still waiting for pics of the other ones. "Studio" models in black. They're supposed to have different tweeter placement.
    I DON'T have to have any speakers just now. I just want the GOOD SDA's.
    I've got a pair of AR9, AR9LS, and AR90s, I just went through all of them and they sound fantastic. I've also got a pair of Klipsch Chorus II, '78 Cornwalls, Altec Valencias, Jensen 60's era Auditoriums, and a half dozen pairs of bookshelfs laying around IN THE APARTMENT right now to listen to. I'm a freak for good speakers and the SDA are on my WANT NOW list. I'll find the right ones sooner or later. Hopefully the "studios" will fill the bill.
    I'll let you know more as I do.
    Thanks to all again,
    Harry
  • Face
    Face Posts: 14,340
    HB27 wrote: »
    They're probably 1C's or 2B's, you can't go wrong with either one as long as the price is right. Did he say how many woofers/tweets?
  • HB27
    HB27 Posts: 1,518
    4 woofs and 2 tweets
  • Ricardo
    Probably 1B's or 1C's. . Both are very good SDA'a, so if they are in good condition and the price is right, go get them (remember you will probably want to spend $200 to upgrade tweeters to the RDO's)
    SOPA
  • HB27
    HB27 Posts: 1,518
    I've got to figure caps also. Sonicaps aren't cheap. I hope they're the C. I'm not a big fan of black but It's a possible keeper speaker. I can re-finish/veneer if needed.
    h
