Choosing a new system
I was hoping for some help choosing the speakers for a new system - here is what I have identified so far:
RTi 70s - fronts
CSi 30 - Center
RTi 28s - Surround
PSW 303 - Sub
I am running a Yamaha RXV 620 Receiver and a Toshiba SD 1800 DVD. I do not have a lot of extra cash and I am trying to stay within a budget of $2000 CDN.
Do the RTi 70s overwhelm the other products included here? I have thought about exchanging the RTi 28s for the FXi30s?
Desperately wanting to decide,
Thanks,
Old Scot
RTi 70s - fronts
CSi 30 - Center
RTi 28s - Surround
PSW 303 - Sub
Thanks,
Old Scot
Post edited by Old Scot on
Hey Old Scot-
That sounds like a great speaker list. The Rti70's have a really nice sound to them. IMHO the most important swap you could make for yourself would be the Csi30 for the Csi40- YOu will really notice a difference between the two, and a really nice center is pretty important. I looket it up on Polks website how much this would all cost, and it came out to a bit over your budget with the Fxi30s. If it makes much difference, you can buy the Csi40 all day on ebay for around $300 (US) shipped. If you are set on a Csi30 I am sure it would quite well in a home theater setup. I would recommend going to your local Circuit City and having a good long listening session and really find out what you really like. Take it easy, I hope this helps you out. Mike -
Having just made the upgrade to the RTi70's, I suggest getting something bigger then the 303. You won't even notice it's there. Saturday I took back my velo cht 8 (thank you CC 1 yr upgrade) because the bass provided by the 70's made the sub useless. I got the 404 (frequency response a little better then the same size velo) and have noticed a little difference. Jury still out as I haven't had sufficent time to play with it yet.Pioneer Elite VSX-21TXH
Monolith 7x200 Amplifier
Harmony Hub
Sony VLP-HW40ES
Visualapex 106" Electric Screen
Oppo BDP-103
Music Hall MMF 2.1
Polk LSiM 705
Polk LSiM704c
Polk LSiM702F/X
SVS PB-2000 -
Hey there,
Well, I can tell you that the RTi70's are an excellent choice, and I agree with the CSi40 over the CSi30, but don't get me wrong here. I "test drove" the CSi30 as well, and it is also a great sounding center - I just think the CSi40 better matches the RTi70's if you're concerned about a perfectly matching front soundstage - and yes, the CSi40 is more expensive, but worth it. The center channel speaker is the most important speaker in your system.
The FXi30's are incredible speakers, and I highly recommend them over RTi28's, if you are more interested in movies than music because of their bipole/dipole feature. If you are as interested in music just as much as movies (not me, I'm primarily a movie guy), then the RTi28's or RTi38's (being direct-firing speakers) are a better choice, I believe.
Hope that helps.
KevinMains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688 -
Thanks for the responses all. I have decided to splurge more than my expected budget (budgets were meant to be exceeded weren't they) and I am going to add the CSi 40 Center. The jury is still out on the Sub however.
Once again thanks! -
up grade your sub, that will be the best for the money, a good sub is worth its weight in gold. rt-7 mains
rt-20p surounds
cs-400i front center
cs-350 ls rear center
2 energy take 5, efects
2- psw-650 , subs
1- 15" audiosource sub
lets all go to the next ces. -
Well here is where I ended up (When the RTi70s came through the door - divorce loomed - they are now being returned :-( ).
Fronts: RTi 38s
Center: CSi 40
Surround: RTi 28s
Sub: PSW 404
Overall I think I have ended up with a decent system:-) What do you think?
Old Scot -
Sounds like a great system.
Let me get this straight though, the *wife* wouldn't let you keep the 70's, but she doesn't have a problem with 38's on stands?
And contrary to popular belief, ALL speakers are important in home theater, not just the center. Lookin' good Scott.
Cheers,
My wife actually liked the towers (70's) over the stands and rti55's we had, we had the csi30 and liked it, just was able to pick up the csi40 "real" cheap and nabbed it, the 404 when setup right can definatly make a big difference and anyone who can't tell much difference maybe needs to calibrate it, or turn it up.. The 303 was nice when im listened to it at CC but the 404 was the best... The 70's are nice and i have had them for almost a year...MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
