Need advice!
If you had your choice between SDA 1 C's or SDA SRS 2.3tl's - which ones? (And Why). Driving 195 wpc - Crown Amp DC 300A Series Amp w/ Carver C-17 preamp. For pole barn - 30 X 80. I really appreciate the imput.
Post edited by Crazy Jon on
In that space get the 2.3TLs and a bigger amp. I own the 1Cs, never heard the 2.3s, but have heard the 1.2TLs. Aside from bass performance, in a smaller room, I prefer the 1Cs. The larger SDAs project a larger soundstage with deeper bass. In a barn, the bigger the better and 195 watts will work at reasonable volume levels. If you want to fill that space (if you can) something heftier might be in order.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
SDA SRS 2.3tl's
no brainer
the bigger the amp the better
