Breaking in my speakers
socaljeeper
socaljeeper Posts: 15
edited September 2008 in Speakers
What if at all do you have to do to break them in? And what happens if you dont do it? and how long does it take? Thanks
Post edited by socaljeeper on
    F1nut Posts: 52,005
    Just play them, they'll get there.
  • jwhitakr
    jwhitakr Posts: 568
    There is no hard and fast rule. F1 is right ... just give them some serious play time and they will get there.
    My HT
    HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
    AVR: Harman Kardon AVR 235
    Video: 80GB PS3, Toshiba HD-XA1 HD DVD
    Fronts: Polk Audio RTi8
    Center: Polk Audio CSi3
    Amp: Emotiva LPA-1
    Surrounds: Polk Audio R150
    Sub: HSU STF-3
    The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
  • BjornB17
    BjornB17 Posts: 752
    A bat is one way to break them in
    KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
  • curved
    curved Posts: 664
    These are the steps that I took to break-in my RTi8's the right way:
    -Make Jack and Coke
    -Kick off my shoes
    -Planted my behind
    -Layed back and let the tunes play
    In all seriousness, just don't push them too hard right away.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • steveinaz
    steveinaz Posts: 19,546
    +1 to all the above. Save any serious listening for about 30 days--tweeters will smooth out, and bass will probably increase slightly as surrounds loosen. You notice it more with some speakers than others. My Athenas definitely gained noticeable bass after about a month, my Energy's, not so much.
  • zingo
    zingo Posts: 11,258
    For break-in, I usually do about 25% pink noise and 75% music; and I try to let the speakers run for at least a week straight. That is my recipe for success, but they will also just break in on their own as mentioned.
  • ShinAce
    ShinAce Posts: 1,194
    To break in a woofer for spec testing, I use a 20-30 Hz tone at moderate volume for hours on end.
    To break in a speaker, I would just push them hard enough at first and cut the treble back a few dB for the first day or two. Harsh highs kill me.
