help a n00b with db6501 crossover
tonyk72
tonyk72 Posts: 3
edited September 2008 in Car Audio & Electronics
I have a stock system in an '04 GTO and want to install the db6501 system. The stock system has tweets in the dash and speakers in the door panels. I assume I wire the new speakers to crossover but what I don't know is what do I wire to the crossover input? :confused:
Post edited by tonyk72 on
  • Kinetic
    Kinetic Posts: 437
    use the imput from the door speakers
    and cancel the imput of the original tweets.
    Z
    /////Alpine CDA-9887 HU
    /////Alpine KTX-1000EQ
    /////Alpine PDX-4.150
    /////Alpine PDX-1.1000
    Polk Audio SR 6500
    Polk Audio SR 124 DVC
    KnuKonceptz MKS Kable
    G35
    /////Alpine SPX 17PRO
    /////Alpine SWX 1243D
  • sponger
    sponger Posts: 325
    The db6501 is a component speaker system if I'm not mistaken.
    This means it comes with tweeters, midwoofers, and a pair of crossovers.
    Each crossover should have 3 sets of +'s and -'s.
    The +'s and -'s on the far left is where the amp hooks up to.
    The middle set of +'s and -'s is where the midwofer hooks up to.
    The +'s -'s on the far right is where the tweeter hooks up to.
    It's in the manual.
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
  • tonyk72
    tonyk72 Posts: 3
    Kinetic wrote: »
    That's what I thought. But how do I cancel the imput of the tweets? Do I just leave the original speaker wire hangin'?
  • tonyk72
    tonyk72 Posts: 3
    Anybody? I'm ready to do the job tomorrow...
  • exalted512
    exalted512 Posts: 10,735
    Actually, you want to use the signal for the tweeters. Just leave the door speaker harness tucked away in the door somewhere so it doesnt get tangled in the window track.
    -Cody
