Any changes to settings for Surroundbar 360?
I recently purchased a Surroundbar 360 and a DSW Pro 400 subwoofer. The system sounds really good without the sub, but I can certainly tell a difference when I turn the sub on. In regards to sound, the only thing you can change on the SB 360 is treble and bass. I just wondered if I should alter these settings (alter from the default), since I'm using the sub.
Post edited by jcjrogers on
I did some Beta testing on the SB360 and really liked it overall. The bass is suprisingly good for the size and use of smaller drivers, in contrast to the other Surround Bar models.....but ya' gotta use that subwoofer
It really fills out the big picture.
You should set them to what sounds best for your room. Got pics?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Here are some pics. Don't know if you can tell alot. The room is like 23' long and 16' wide. However, the furniture is covers only about 1/2 - 2/3 of the room.
