Dayton Speaker Cables?
TomB
TomB Posts: 106
I'm getting ready to place an order with Parts Express for capacitors, resistors, solder, etc to upgrade the crossovers in my Monitor 7Bs. (I started a thread over in the Vintage section with questions on that project.)
While I have an order going, I was considering ordering a pair of these:
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=181-600&ctab=1
I know they're nothing special, but the price is right, and I suspect they'll be an improvement over the Monster Cable Clear that I've been using forever.
One problem: my 7Bs will accept the banana plugs, but my old Harmon Kardon receiver just has the cheap-o terminals where you push a button, insert the stripped speaker wire, then release the button to grab the wire. (I've never liked those connections.)
I hate to just cut the plugs off of the Dayton cable and strip the wires. Will I be able to un-solder the banana plugs, so I could reinstall them later, when I get a better receiver or amp? Is there some terminal or adapter that will go from a banana plug to a bare conductor?
Thanks. Any ideas will be appreciated.
Post edited by TomB on
  • dc55110
    dc55110 Posts: 128
    edited September 2008
    Add these to your purchase: Dayton SPINGS-2MM Speaker Pin Compression
    (((STEREO)))
    Sony DVP-N9000es
    Squeezebox Duet
    Theta ProBasic IIIA
    Audio Research SP14
    White Audio Labs B1
    Transparent SoundWave Super
    Paradigm Studio Monitor
    B&W 802 s3
    HT
    Sony Bravia KDL-40Z4100
    Sony BDP-S350
    Yamaha HTR-5790
    NHT SB3 (Fronts)
    NHT SC2 (center)
    NHT SB2 (surround)
    Velodyne FSR12
  • TomB
    TomB Posts: 106
    Thanks, DC and Keiko. I take it that my receiver will accept those pin-type connectors? If so, there is an adapter on the e-z hook website that has a banana socket and a pin plug that will do the trick.
    Is there any problem with having that adapter in the cable on a long-term basis? The website makes it look like these things are intended for testing purposes, which I assume would be only temporary.
    Maybe I'd just be better off getting some decent speaker wire, banana plugs and pin plugs and putting my own cables together. I know speaker cables are a big deal around here, and that I can get them custom-made with any terminals I want, but that's a bit more money than I wish to spend.
    Thanks again.
  • ben62670
    ben62670 Posts: 15,969
    I hate to sound like a broken record, but... AudioQuest Type4 works much better than standard cables without needing connectors. $4 a foot, strip the ends, and you are done. Nothing fancy, but real good SQ.
    Ben
    Ben
  • daboyz
    daboyz Posts: 5,207
    The 5000UE is an excellent cable,I have it running to my rears. But, the AQ Type 4 is superior. If you're patient you can get some great deals on the bay.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I agree with both Ben and daboyz.
    The AudioQuest Type 4 would sound very nice and you're done for a while or ever.
    The Belden 5000UE cable sounds very nice also I ran a lot of that in my walls, sounds very nice also but a step or tow under the AQ cable. But if you need to installed 600' of it the 5000UE cable is very very sweet then. ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • TomB
    TomB Posts: 106
    Thanks for the information, everyone.
    The Belden cable is quite inexpensive - and heavy duty! 10 or 12 AWG would be a bit of overkill for me, I think.
    The Audioquest Type 4 is real purdy, and the price isn't bad. There's a very esoteric explanation of how it works on one of the websites. Hmmm...
    Ben, if I just go with stripping the ends on the Audioquest, without terminating, how do I deal with the separate conductors - just twist them together, and then use the holes in the binding posts on the speakers, as I'm doing now? And the same way back at the receiver? I know they're solid conductors, but they're small enough to handle that way, it looks like.
    Thanks again.
