What gauge wire should i use?
Shank265
I have 2 10" kenwood db+ with the polkaudio c500.1 monoblock and i was wondering what gauge wire i should use. i currently have 10 gauge but i was also thinking about putting a capacitor in it. If i put in like a 8 gauge would that be good or should i go bigger? And if so do i need a new altinator for my car because i think it is stock.
with that much wattage ur alt is fine, even stock, a cap is a waste dont put one in. go with 4 gage.2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
Running power wire is a pain. You are likely to want to upgrade your system some time in the future. Go with 4 ga. It is large enough to allow another amp later on, still flexible enough to making routing the wire easier. Besides, connectors , accessories, firewall plugs, etc are readily available."You can tell by the kindness of a dog how a human should be." Don Van Vliet
