RTiA3 or TSi200
Just would like to know what most of you would choose between the two for your main speakers in a all music system.
Post edited by Doc99 on
The TSI series speakers haven't been out for a long time. Both are good speakers while the RTI series is a step up in quality deals can be had on them.
I'd check ebay for a pair of RTi6's. They can be had for about $200 shipped and will likely cost less than either of the 2 speakers you mentioned. The RTi6 is better than the TSi200, and pretty much equivalent to the RTi A3.KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
Rti a3's on ebay for $199 but it now.
I don't think there are many people out there who have heard these two series compared against one another. Right now most people are going to give you conjecture. If you are able to do so, I'd audition them both and then decide based on your experience.My HT
HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
AVR: Harman Kardon AVR 235
Video: 80GB PS3, Toshiba HD-XA1 HD DVD
Fronts: Polk Audio RTi8
Center: Polk Audio CSi3
Amp: Emotiva LPA-1
Surrounds: Polk Audio R150
Sub: HSU STF-3
The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
