Remote turn on wires
TouchOfEvil
I searched but came up with very little on this subject and i am having some trouble getting my amps setup for the remote turn on.
I have two rotel amps one is a 1050 the other is a 1075
Both have remote turn on but what wire do i need for this?
I thought it was a 3.5mm jack so i got one from radio shack but i plugged it in and no dice.
Did i get the wrong wire type or what guys?
Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
Xbox360/PS3/WII
M.Br. setup:)
Computer Rig:
Are there any other switches or buttons to adjust the settings to "enable" remote turn on? Are there "in" and "out" jacks? Can't hurt to double check your work."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
The 1075 has a switch to enable the remote turn on the 1050 does not.
They both have in and out jacks.
At first i only had the 1075 amp so i plugged in the wire from the output on the amp to the input to the AVR.
That didn't work so i reversed it and went from output to input and so on...tried all kinds of ways but nothing.Living Room Rig:D
Xbox360/PS3/WII
M.Br. setup:)
Computer Rig:
