How to fix Csi5 "blemish"
NewHTguy
NewHTguy Posts: 584
edited September 2008 in Speakers
I just received my new Csi5 (black). It was an open box deal at Amazon listed as having "cosmetic blemishes." It is in great condition except for a minor scratch in the finish. The scratch is not deep enough to have affected the wood, only the black finish. Aside from painting the whole thing, which is hard to justify given that it is so minor, is there any easy way to fix it?
MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
BENCHED: CS20; OWM3s
Post edited by NewHTguy on
  • dorokusai
    dorokusai Posts: 25,640
    Sharpie.
  • leroyjr1
    leroyjr1 Posts: 8,785
    Black sharpie worked great for me also
  • NewHTguy
    NewHTguy Posts: 584
    dorokusai/leroy,
    Thanks for the advice. I'll give it a try, although in some light I can't even see it.
  • jwhitakr
    jwhitakr Posts: 568
    If you can't see it in some light, it sounds like it is very minor. Sharpie it and forget it!
    My HT
    HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
    AVR: Harman Kardon AVR 235
    Video: 80GB PS3, Toshiba HD-XA1 HD DVD
    Fronts: Polk Audio RTi8
    Center: Polk Audio CSi3
    Amp: Emotiva LPA-1
    Surrounds: Polk Audio R150
    Sub: HSU STF-3
    The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
