Polk Audio RTI A5 vs Monitor Audio RS6
Polk Audio RTI A5 vs Monitor Audio RS6. Who is campare this speakers? What is you impression about monitor audio ?
Post edited by 1render1 on
Personally I like the way the MA sounds over the RTiA5. I listened to both several times (although not next to each other) and was about to get the MA. Then I found the RTi8's online and took advantage of the great offer - got a pair of them cheaper than I could get 1 MA RS6 for.....
MA Advantages:
-Not quite as bright.....still on the bright side
-more detailed mids
-better soundstageLiving Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
oh ya.....and you'll need some good power for the MA's.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
MA Advantages:
-more detailed mids
-better soundstage
I understand that, monitor audio rs6 is better polk audio rti5? How monitor audio play with the onkyo sr 805? -
And one more.... in my country price on RTI A5 and RS6 is the same.... what you recomend me go with the onkyo sr 805?
The Onkyo 805 is a great receiver. Give it a try.
I know that onkyo 805 is a great receiver, but i don't know how it play with monitor audio speakers RS6. In my country is a problem to buy polk audio... But i hear from people, that monitor audio RS6 is better than polk audio A5. But I can't compare this speakers, because polk audio i can only order and buy without listening it
. Ca you help me in my choise?
Thank you -
I have not listen to the Monitor RS6's , but I can tell you the RTI a5's sound great.
Are you looking for a good music speaker or home theater speaker? 2 channel listening or 5.1. -
home theatre 5.1 , I read about rti A5 positive feedback, but I can't compare it's with monitor audio RS6 -
Lee - Flanner's has them in. Also check out the MA PL300 - INSANE!!
I think you would be fine with your Onkyo, although I didn't hear it matched with an Onkyo so I can't be certain. Also, the RS6 is a 6 ohm speaker, so you Onkyo may run a little warmer than it would with the Polks.
Either speaker, you can't go wrong....Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
I have both the rs8's and the rta5's in my home. the rs8 don't require a lot of power to sound great in my opinion. have listen to both sets of speakers on a b&K amp and a little nad stereo amp about 60watts. They sounded great with both. I prefer the rs8 for music. I haven't tried them in home theatre. If you can get the rs6 for the same price as the rta5's I say it's a no brainer. Go with the rs6's. The Onkyo is probably a better match them as well. Considering the they are less bright.Front - RtiA5's
Surround - RtiA1's
Center - CsiA6
Sub - Velodyne DPS12
B&K Ref 50 Pre
Amp - B&K AV5000 II
Ben's Silver IC's -
andrew_mac wrote: »I have both the rs8's and the rta5's in my home. the rs8 don't require a lot of power to sound great in my opinion. have listen to both sets of speakers on a b&K amp and a little nad stereo amp about 60watts. They sounded great with both. I prefer the rs8 for music. I haven't tried them in home theatre. If you can get the rs6 for the same price as the rta5's I say it's a no brainer. Go with the rs6's. The Onkyo is probably a better match them as well. Considering the they are less bright.
Thank you!
I think, I will buy monitor audio RS6 for my home theatre.
Thank you for your advice!:) -
Let me know how they sound when you get them.
I had listen Monitor audio rs6 rs1 rs rlc and sub from this series... with yamaha v1800 and s2700, I don't know why may be yamaha not suits with monitor rs6 , but sound is the SUX :eek::eek::eek: I very disapointed in monitor audio
. Some people told me that monitor rs6 good play with the marantz but not with the yamaha. -
What kind of music do you listen to? Was it muddy, bright, too mechanical, etc?
Get an amp with the RS6. Something a little more laid back sounding - NAD, Roksan, Adcom....Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
You may have to give it time to break in. I'd imagine if you are using a receiver, it might sound a bit bright on some. Marantz or HK might be a better AVR match. Or just grab a decent amp.-Ignorance is strength -
I don't believe the Silver RS series to be much better than the Polk. If I was to pick anything out...it would be the high end response. It's a bit smoother, which I believe was mentioned previously.
I'd really like to hear the Platinum series from MA at some point.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I listen the Lenny Kravitz.... sound from monitor audio have been sux :eek:.
Recentrly I listen speakers DALI IKON 7, this speakers sound is amazing... CONCEPT 6 very good speakers for this price, but IKON series is a very ugly
:D:D, but sound fantastic.
You can't compare the Dali's to the MA RS6......they are in a totally different price range - $2000-$2600. MA's will run $1000-$1200
Let them break in a little - keep bass and treble at 0 or no +/- gain. If the recording is bad, you will hear it with these speakers. Very accurate reproduction - just a little on the bright side. With your type of music, I don't think you would be any happier with the RTiA5's.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
I owned the MA RS6's for a few months, and was very pleased at the performance/price ratio. To some, they may sound a bit forward. but my opinion was that they were pretty well balanced overall. If you can find a dealer to give you a ~20% discount off MSRP, I think they're hard to beat for the price...
In my country price on dali ikon 7 and monitor audi rs8 is the same, but concept series is more expensive than a monitor audio rs6, but sound is beter from concept. I don't know why rs6 with the yamaha v1800 sound have been sux...:( I very disapointed in this speakers. -
I'm telling you to get a warmer amp and you'll love these things. If you're using Yamaha, I'm guessing it is very fatiguing on the ears - very bright!!
Better yet, bring these into the store and find an amp that fits the bill. You can use the Yami as a pre...Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
