Pre Amp?
Pinktulip7
I have Polk Rti A9 connecting through Carver M500t ,should I get better Pre-Amp?Any suggestion?
TV :>Panasonic TC-P55VT50
RECEIVER :> HARMAN KARDON AVR 7300
FRONT :> L & R :> POLK RTI A9 500 W
AMP :1> PARASOUND HALO A21 250 W
AMP :2> EMOTIVA UPA-1 200 W
CENTER :> POLK LSiM 706c 250 W
SURROUND SIDE :> POLK RTi A3 150 W
SURROUND REAR :>POLK FXI A6 150 W
DVD PLAYER(HD) :>TOSHIBA HD X-A2
DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
POWER CONDITIONER :> PANAMAX M5400-EX
SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
Post edited by Pinktulip7 on
Isn't the Carver you reference a power amp? What are you using for a pre now? What source components do you have?DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
using Carver M500t as a pre amp...TV :>Panasonic TC-P55VT50
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear -
Huh?
TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
http://www.polkaudio.com/forums/showthread.php?t=21534
I think you are using the HK AVR as your pre/processor and the Carver as a power amp, per what I see in this thread? I don't see the speakers you reference in your post in the gear in your sig, so are you replacing the RTi12's or building another system for 2 ch music listening? Give us all the info you can!DKG999
Pinktulip7 wrote: »using Carver M500t as a pre amp...
I thought the M-500t was an amp.JC approves....he told me so. (F-1 nut) -
I replaced Rti 12 with Rti A9,same System..I connect Carver M500t to HK 7300 's pre-out then connect RTI A9....TV :>Panasonic TC-P55VT50
U guy got me all confused..pls forgive me for lacks of knoledge!!!difference between AMP And Pre-AMP?TV :>Panasonic TC-P55VT50
afaik the Carver M500T is just a power amp.. with huge meters on the front.
I believe this is it..PolkFest 2012, who's going>?
Yes thats it....TV :>Panasonic TC-P55VT50
for a pre amp to work it must be connected to a amp.. (power amp).
so you would connect your CD player to your pre amp, connect the pre amp to the amp.. then connect your speakers to the amp. then you get awesome sounds.
so whats does it mean?My set up is a mistake?TV :>Panasonic TC-P55VT50
that exactly what I have done!!!danger boy wrote: »for a pre amp to work it must be connected to a amp.. (power amp).
so from your list of equipment it appears you are using your RECEIVER the HARMAN KARDON AVR 7300 as your pre amp.. and using the Carver as your amp.
nothing wrong with that.. but to bring the quality up.. it would be best to buy a stand alone pre amp. since you already have the Carver amp.
If you're happy with it, leave it be. But if you're really itching to upgrade, how much are you looking to spend?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Stand alone Pre Amp!!!what u suggest?or replace Carver for better Amp?TV :>Panasonic TC-P55VT50
$500 to $750...:eek:If you're happy with it, leave it be. But if you're really itching to upgrade, how much are you looking to spend?TV :>Panasonic TC-P55VT50
Any suggestion on high end Dvd player?currently using Sony?TV :>Panasonic TC-P55VT50
the Carver amp is fine... i'd look into a different pre amp.. depends on what you want to accomplish though.
let us know if you are using this for only listening to 2 channel or are you looking to build a 5.1 surround sound home theater.PolkFest 2012, who's going>?
I already built 7.1 through HK 7300....now want to build 2 Channel StereoTV :>Panasonic TC-P55VT50
Pinktulip7 wrote: »I replaced Rti 12 with Rti A9,same System..I connect Carver M500t to HK 7300 's pre-out then connect RTI A9....danger boy wrote: »so from your list of equipment it appears you are using your RECEIVER the HARMAN KARDON AVR 7300 as your pre amp.. and using the Carver as your amp.
There's your answer.TNRabbit
Sunfire TG-IV
You can typically buy used Carver pre-amps and pre-tuners used often in $ 150-$200 range. The Adcom pre-tuners were also good performers that typically sell in that price range as well.
