what speakers?
socaljeeper
What other pair of speakers should I get. I want another pair of bookshelf speakers. Should I get rti Series or rti a series? I have already Rti a1, csi3, psw505 sub. I will mainly be using it to listen to music. And why should I get that speaker.
Post edited by socaljeeper on
Get another pair of RTi a1
* sounds great
* very affordable
* matches the pair you already have
* stylish curved cabinet
How do you like the RTI A1's you already have? You can also try the big brother to the A1 the RTI A3. It will sound better upfront. -
Do you think I should get matching speakers to my center channel and then move the ones I already have to the back of the room?
I like the A series better for music, not as brght. I think the csi 3 will do fine with the RTI-a series.
thank you for the help. should i get the a1's or a3's?
If you have the budget get the A3's. It can be had from Polks ebay store for $219 plus shipping or the A1's can be had for about $130 plus shipping.
Thank you very much.
I recommend RTi a1
