Polk RTi8 vs RTi6 for music, computer
I'm considering either a pair of RTi6's or RTi8's for an office setup to play music and for general computer use. Which of these 2 speakers would you guys recommend? I won't be using these with a sub.
KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
Post edited by BjornB17 on
Well, just my novice opinion, but the 8s are towers and the 6s are bookselfs. The 8s have more drivers and reach lower at the -3b level, so if you aren't using a sub and this is for music, I'd go with the 8s.
Towers in an office??? Must be a big office!
Erik Tracy wrote: »Well, just my novice opinion, but the 8s are towers and the 6s are bookselfs. The 8s have more drivers and reach lower at the -3b level, so if you aren't using a sub and this is for music, I'd go with the 8s.
thanks for the input
The office isn't very big, but i figured i will need to put stands on the 6's anyway so they will take up the same space. KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
Have I got a deal for you on some Sanus stands! :-)
Erik
