I need a PC digital out to RCA coax in
fbm211
fbm211 Posts: 1,488
Any one know where I can get a cable like this.I have a xFi fatal1ty pro sound card that has that mini digital out.Id like to run it to my DAC.
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
  • Face
    Face Posts: 14,340
    edited September 2008
    Blue Jeans Cables can make a 1/8" to RCA digital cable, I use one with my X-Fi card.
    Check out the 1505F.
    http://www.bluejeanscable.com/store/digital-audio/index.htm
  • WilliamM2
    WilliamM2 Posts: 4,810
    Not sure what you mean by "mini digital out"? If it's an 1/8" mono jack, you can use a simple adapter like this, and then a standard coax cable.
    http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040109&p_id=680&seq=1&format=2
  • Face
    Face Posts: 14,340
    BJC claims their 1/8" jack is 75" ohms, which is important for a digital cables.
  • WilliamM2
    Face wrote: »
    If he uses a 75ohm coax cable after the adapter, it's the same thing. When I said standard coax, I guess I should have specified "digital coax" cable.
  • fbm211
    fbm211 Posts: 1,488
    Thanks .A 8ft 1505F mini to RCA is 25.00.Not to bad.
