Acurus L10 Line Level Preamp Mint Condition!
Kahuna
I have an Acurus L10 Line Level Preamp For Sale. It is in superb condition and preforms perfectly! - This line level preamp is extremely simple, as preamps ought to be, and is ultra clean with regards to both signal performance and physical condition - appears like new. The topology was designed by a former Krell engineer (William Snyder). It utilizes a fully discrete power supply regulator with no global feedback and fully discrete line stage topology. Neutral, transparent - the way the music was meant to be heard!
Very intelligent and solid build. Five identical knobs arranged symmetrically across the thick anodized aluminum faceplate: 1 -- Off/On/Mute 2 -- Volume 3 -- Balance 4 -- Listen Switch 5 -- Record Switch
Specifications: Frequency Response -- 20 to 20000 Hz +0.0, -0.15 dB Total Harmonic Distortion -- 0.06% Signal to Noise Ratio -- 95 dB, A weighted High Level Sensitivity -- 60mV Maximum Output Voltage -- 8 Volts RMS Voltage Gain at Full Volume -- 18.8 dB Input Impedance -- 10K ohms Output Impedance -- 47 ohms Tape Outputs -- 2 Preamp Outputs -- 2 Inputs -- 6 (CD, D/A, Tape1, Tape2, Tuner, Aux) Price: $285 + shipping
By Kahun_a
By Kahun_a
By Kahun_a
By Kahun_a
Post edited by Kahuna on
Hi Kahuna,
Do you have the remote control? -
Hi Kahuna,
No remote on the L10. You need the RL11 for a remote. -
Ahhh- thus the R. Makes sense. Do you know what the difference is between the two? I've been looking for a RL11 (my friend's sounds great!). If they're similar, maybe I'll try the L10.
Thanks for your time!
-Phil
www.philpalombi.com -
Hi Phil,
Other than no remote (with the L10) I believe they are identical, but don't quote me on that. (I would guess someone here on this website could more accurately answer his question). Thanks! K. -
Sale Pending.
