Deutscheland White Vans
George Grand
George Grand Posts: 12,256
edited September 2008 in The Clubhouse
In my travels today, skinny towers about the size of RTA 8. Marketed under the name Cat, with a cougar or jaguar as part of the metal emblem on the front. Total failure on the knuckle test. Three **** drivers on the front baffle and maybe an 8" but more than likely a 6" side-firing job too. Nothing but German writing on the back. Coming soon to a parking lot near you.
Post edited by George Grand on
  • Lowell_M
    Lowell_M Posts: 1,660
    What is the knuckle test?
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • George Grand
    When you rap on the cabinets and your knuckles go through cause they're made out of glorified balsa. You get that ringing sound that shouts "No bracing whatsoever!"
  • nadams
    nadams Posts: 5,877
    I've never had the pleasure of being white-vanned. I'm in too rural of an area... The Amish would make GOOD cabinets, just with no electronics in them :p
    Some day, I hope to run into a white van group and see if I can get them to prove how stupid they are, without them realising it :). While the girlfriend sits in the car and calmly calls the cops...
    Ludicrous gibs!
  • John30_30
    John30_30 Posts: 1,024
    The Amish would dovetail-joint 3/4" MDF. That's a scary thought, but then they'd fix it up pretty with knotty pine veneer. Or cherry. Or chestnut. Or walnut.
  • Lowell_M
    nadams wrote: »
    Where are you from in PA? I've almost run over my fair share of buggies around the state.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • Rivrrat
    Rivrrat Posts: 2,101
    I've been white vanned once when I was younger. They insulted my gear, and I laughed at theirs.
    I guess we were even.
    My equipment sig felt inadequate and deleted itself.
  • sucks2beme
    sucks2beme Posts: 5,699
    Nothing says good deal like a couple of tattooed ex-cons
    cruising around in a white van trying to sell "extra" speakers.
    You know all quality speakers have the list price on the box
    in big letters.
  • Lowell_M
    George... You ever try out that Entech DAC?????
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • BjornB17
    BjornB17 Posts: 752
    I am going to create a company called White Van Incorporated.
    KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
