Replacing My RT55's
In the past 10 years I have replaced my elecronics 4 times but my speakers remain constant.
I thing it's about time looking into upgrading them, I have an open room so I need something that would fill that space.
I was thinking about the RtiA9-A7 or the SVS MTS-01.
Fronts RT55
Center CS400
Surround FXi50
Rear RT25
Sub SVS 20-39+
Integra DTC.9.8
BA 7200
Your thoughts would be greatly appreciated.
Peter
Fronts RT55
Center CS400
Surround FXi50
Rear RT25
Sub SVS 20-39+
Integra DTC.9.8
BA 7200
Peter
Post edited by peteran on
What is this mostly used for? How big is your room?Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
I would save the money by keeping the sub you have, as the bang for buck just isnt going to be there in that direction in my eyes.
now a front soundstage upgrade.......thats a good thing. I have mad respect for the RT55 CS400 combo, but if your feeling its the time to move on, then it is pretty much time to move on.
the RTi series would be a move up in my eyes.......but if you take the money you were going t spend on the sub, maybe go the LSi front stage route. while it wont be timbre matched with your surrounds, it will still work fine, and your front stage will be on point.
that BA7200 you list, is that an amp? if you....even better. The Integra could probably do the LSi fronts fine, but beefy amplification either now or down the road will make them sing even more.
just my .02, believe me, the RTi series will probably make you happy as a clam too, but I know from experience that I have the LSi, and havent considered an upgrade in years, with no plans to in the futureLiving Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
Ohskigod, thanks for your input.
Main purpose is for movies, yes the BA7200 is and amp(120x7). As far as Lsi series is concerned iwould love too but I will have to get a bigger amp to feed it and probably upgrade the 2 outlets(circuits) that i'm using to 20amps.
I'm not changing the sub, very pleased with it. So wil it make sense to get RTiA7 instead the RtiA9?
I have been very happy with the RT55's but for some reason i feel that I'm missing something.
Has anubody heard about the MTS series from svs. Even on the AVS forums there is not much discussion. -
I have the RT55i as my main, the CS400i center and the FX300i rear surrounds. I have no desire to replace my current setup. IF I decide to change, it would be nothing more than replacing the RT55is with my RT400s or upgrading my Dayton Titanic sub. This is mainly a HT rig but it does a very nice job for music as well."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
The first rev of the MTS was criticized for being too laid back and neutral, though some reviewers liked it. If you look at the last page of the AVS thread, the new crossovers are discussed with their results. The last post from the owner of L Sound is pretty telling. The new rev is much improved and if I were shopping they'd certainly be considered.
http://www.avsforum.com/avs-vb/showthread.php?t=865504&page=13
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
