ATTN - CSi4 & CSiA4 owners
How deep is these? On the site, it's roughly 9 inches. Is that with the flared port or without.....my mantle is 8 inches in depth. I won't mind if it sticks out less than an inch, but anymore would be unsightly.
Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors**
Pre - Nak CA-5
BR - LG BD390
Post edited by curved on
The csi a4 doesn't have the power port on back. I just sold mine so I can't measure but you should be ok.
I'm going to downgrade to either one.....the CSi5 and CS400 don't come anywhere close to fitting - they are both HUGE!!!Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
**Dayton and Sonicap Caps with Mills Resistors** -
You can get the csi 3 on ebay for about $125 shipped
This is your best bet. Jump on it. It's a perfect match for your RTI 8's
http://cgi.ebay.com/New-Polk-Audio-CSi3-Home-Center-Channel-Speaker-Black_W0QQitemZ260285093475QQihZ016QQcategoryZ3276QQssPageNameZWDVWQQrdZ1QQcmdZViewItem -
I think you meant "CSi3 and A4". I can measure my unused CSi3 for you. Will you have it on the flat side or angled up?
I have the CSi3 and no it does not have the rear port.
The specs on the Polk Site are accurate for its depth.
I have the CS1 A4 and it is exactly 8 inches deep and just shy of 7 inches tall (without rubber feet) on the face. You may wanna give it another half inch deep for speaker wire.Onkyo TX-SR705
Polk RTi A5
Polk CSi A4
Polk FXi A4
Martin Logan Dynamo -
VSchneider wrote: »I think you meant "CSi3 and A4". I can measure my unused CSi3 for you. Will you have it on the flat side or angled up?
That's what I meant:p
It will sit on my mantle with the slanted part on the top. I will probably even have to tip it down because the mantle is about 4 feet off the ground.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
