Security Cameras -residential
Mike682
I was wondering if anyone here works with/has experience with home surveillance systems.
We want to buy a baby monitor and were looking at this one:
http://www.amazon.com/SVAT-GX5201-Wireless-Portable-2-5-Inch/dp/B000M8UTZG/ref=sr_1_8?ie=UTF8&s=electronics&qid=1221426113&sr=1-8
Seems like a decent unit. However, as I was searching for baby monitors, home surveillance cameras also came up which got me thinking: Maybe I can also get a basic system w/a DVR to keep an eye on the house when not home. What is a good brand? Does anyone personally use wireless cameras outdoors? So far, I heard mixed reviews about wireless. Most wireless negative reviews mention interference and poor nighttime video.
I saw a few wired systems that seemed ok (decent specs) on Amazon.
For example, this wired system has a dvr and 4 cameras. The dvr also has a usb to transfer data from the dvr to a computer:
http://www.amazon.com/Defender-SENTINEL2-Yourself-Resolution-Surveillance/dp/B001AX81E8/ref=sr_1_47?ie=UTF8&s=electronics&qid=1221426847&sr=1-47
Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29
Mains: polk R30
Center: polk CSi3
Post edited by Mike682 on
Yes, I personally use the higher-end cameras from Sony and Security Labs in my own house, and they work great. I prefer wired over wireless due to the reliability and also the picture quality.
From what I heard, break-ins in Long Island are at an alarming rate, so the first thing we did when we moved in was to install a NEW security system and add cameras around the house.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
if you're considering outdoor use make sure your light levels will be within spec of whatever camera you buy!
For baby monitors we went with this one.
Just get ready for those green little eyes looking at you when it's night time, your child isn't sleeping and they are staring at the camera. It's kind of weird and cool all at the same time.I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff. -
costco.........
Try it and if you dont like it return it.....he he heGodspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
