need full spec ESOSONE 12 inch = 1RD0001-2
nickthevoice
Hello !
I search the FULL SPEC SHEET of this driver 1RD0001-2 = EOSONE 12 inch
because I want create TAPPED HORN SUB but without spec I don't want !!!
# Ohm rating is 4 ohms
# Power is 250 watts RMS (400 watts Peak)
# 2 inch voice coil
# SPL is 91db at 1 watt at one meter
# Freq. Response 20 Hz. to 1500 Hz.
# Part Number on the woofer is 1RD0001-2
# FS - 23.8926 Hz.
# Revc - 3.2038
# Zmax - 21.2296 ohms
# Qes - 0.5382
# Qms - 3.0342
# Qts - 0.4571
# Le - 2.0306 mH (at 1 kHz)
# Vas - 176.2302 L
I need : SD , Xmax , MMD , Cms , BL , MMS ???
nicK
# 2 inch voice coil
# FS - 23.8926 Hz.
# Revc - 3.2038
# Qes - 0.5382
# Qms - 3.0342
# Qts - 0.4571
# Vas - 176.2302 L
nicK
Post edited by nickthevoice on
Welcome to Club Polk.
Have you tried entering the data you have into WINisd?
It should be enough for WINisd to auto calc the rest of the necessary specs to build a box.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
No it's for HORNRESP software to build TAPPED HORN or FOLDED HORN
thanks !
nicK -
Well use WINisd to get the rest of the specs. You will not get the Xmax spec, but that is not needed to design a box. WINisd is free;) After you get your specs plug them in your program.
Enjoy
Ben
