why do my pics suck....test
opus
opus Posts: 1,252
edited September 2008 in Forum Testing Area
Just testing.
do these pics suck? I have worked all morning on camera settings and this is as far as I have got.
The Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre) :)-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer
-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable
Post edited by opus on
  • Ricardo
    Ricardo Posts: 10,636
    I know what your problem is Kevin; picture looks unbalanced. You need two more SVS in the right side :D
    SOPA
  • opus
    opus Posts: 1,252
    Ricardo wrote: »
    I''l give you my wifes number. Work it out for me will ya:p
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • fbm211
    fbm211 Posts: 1,488
    those pics look a lot better than what I get with my camera.I cant get mine to flash in unless its in dusk or twilight mode
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • 66chevyIISS
    66chevyIISS Posts: 857
    what camera are you using? and I agree, needs more subs! haha
    My Home Theater (WIP):
    Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
    Receiver: Denon AVR-1905
    Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
    Dual Subs: PSW202, and behind the couch Denon 8"
    My showcase link:
    Media Room pics
  • opus
    opus Posts: 1,252
    I am using a panasonic dmc-lz7
    I have changed just about every setting I could find. My old pos kodak takes nicer pics than this:mad:
    And Geez....they are Ultra's
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • danger boy
    danger boy Posts: 15,722
    the second picture isn't to bad.. your camera is setting the exposure for what is in the front of the frame.. the rocking chair. cameras don't take a meter reading on the entire room.. the light meter in digital cameras read the brightest spot and set the correct settings for that.
    most all digital cameras you can override some settings. you can also force your camera to have the flash go off even in bright sunlight. I use that trick when taking pictures outdoors to help eliminate shadows caused by the sun. it's a great trick to use.
    PolkFest 2012, who's going>?
  • opus
    opus Posts: 1,252
    danger boy wrote: »
    Thanks DB,
    I reshot a few without the furniture and it is much better. Stills seems to to be a bit blurry.
    Oh well, good enough for the Homecoming pics. Might need to give the police of a picture of my daughters date................., if he disapears(sp) or something. What? I'm just saying.;)
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • danger boy
    if it's blurry.. that is the camera's fault. I have a Sony camera from a few years ago. and every picture is slightly blurry. it's just that it's a POS camera. my newer Canon is much, much better for sharpness. :)
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Some camera's have a picture light meter setting if the "Trigger" button half way down. If so you could point to a darker area of the room then while still half way down turn to where you wish to take picture then press all the way down taking the picture.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    mhardy6647 Posts: 35,029
  • shack
    shack Posts: 11,154
    mhardy6647 wrote:
    tripod :-)
    Yes...also...turn the flash off and get the camera to meter off the farthest subject. The flashes on most P&S digitals are pretty much worthless for anything outside of a few feet. Can you set the ISO on that camera? If so see if you can get it up to 400 or 800.
  • Jeff Beaird
    Jeff Beaird Posts: 217
    disneyjoe7 wrote: »
    I also "fake out" the camera, do as disneyjoe suggests, I hold the trigger halfway, let the camera adjust itself and while holding the trigger readjust to what you want to take the actual picture of and squeeze... wah la... hey, it works for me
    Thanks, Jeff...
  • Sherardp
    Sherardp Posts: 8,038
    Pics dont look too bad, I like the room though. Looks nice and comfy and seems you have space for front projection setup :)
  • McLoki
    McLoki Posts: 5,231
    I would say change the ISO setting to 100 (or lower if possible) and use a tripod. If no tripod is available, set the camera on something, turn on the basement lights and use the timer in the camera so you are not touching it when the picture is taken. See if that cleans up the image at all.
    BTW - nice room. Would be better balanced with a sub on each side though. Never know - it may even sound better.... :D
    Michael
  • zingo
    zingo Posts: 11,258
  • Smock_Dobie
    Smock_Dobie Posts: 12
    mind if I bump this? I need 10 messages so I can PM in a Buy/Sell area
    Dobie
