What Center Speaker To Go With M10s?
SlackerCSB
I received a pair of Polk M10s for my birthday. I plan to use those to replace the front speakers from my Onkyo HTIB. What center speaker should I buy to go along with the M10s?
Would the CS2 work?
Thanks!
Would the CS2 work?
Thanks!
Post edited by SlackerCSB on
You probably should use the CSR for the best match - you could find a great deal on Ebay.
Otherwise a CS1 or CS2 will be fine.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
CS1 and CS2 are higher quality speaker than the CSM so it will sound better (and may give you the urge to upgrade your other speakers, which can be good or bad depending on how you look at it). The CSM is the better match for your system, though.KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
