Trunk setup Pics
ROOGER82
ROOGER82 Posts: 30
edited September 2008 in Car Audio & Electronics
I finally finished my trunk set up. Here are some pics. Sorry I only have some of the completed trunk and not of the progress. Enjoy
In the trunk:
PA 500.4
PA 600.1
DB 1040DVC x2....would have had momo's but they messed up my order.
Tsunami 1.2 Farad cap and Distribution block
Suede false floor
<a href="http://s5.photobucket.com/albums/y190/xl2oGel2x/?action=view&current=trunk2.jpg&quot; target="_blank"><img src="http://i5.photobucket.com/albums/y190/xl2oGel2x/trunk2.jpg&quot; border="0" alt="Photobucket"></a><br>
<a href="http://s5.photobucket.com/albums/y190/xl2oGel2x/?action=view&current=trunk3.jpg&quot; target="_blank"><img src="http://i5.photobucket.com/albums/y190/xl2oGel2x/trunk3.jpg&quot; border="0" alt="Photobucket"></a><br>
<a href="http://s5.photobucket.com/albums/y190/xl2oGel2x/?action=view&current=trunk.jpg&quot; target="_blank"><img src="http://i5.photobucket.com/albums/y190/xl2oGel2x/trunk.jpg&quot; border="0" alt="Photobucket"></a>
(Insert clever sig here);)
Post edited by ROOGER82 on
  • RuSsMaN
    RuSsMaN Posts: 17,987
    Nice clean install, I like it.
  • MacLeod
    MacLeod Posts: 14,358
    Nice work. Better than I could do! :D
    Wouldnt worry about getting DB's instead of Momo's. DB's aint nothing to sneeze at. Im sure youll be pleased.
  • ROOGER82
    ROOGER82 Posts: 30
    now my only problem is that I have 2 pairs of MMC6500...and I can only use 1 since I am no longer fiberglassing my rear deck. So I need some 6x9's to put there, and i need to get rid of one of these components. any suggestions on the 6x9's? would like to run them at 125 RMS just like to fronts.
  • Sherardp
    Sherardp Posts: 8,038
    very clean install. Like it allot.
  • ROOGER82
    ROOGER82 Posts: 30
    Its actually not all done yet...I still need to put in the blue LED's. and repaint the fiberglass a dark grey...or black..have not decided yet. Also the grills
  • Kinetic
    Kinetic Posts: 437
    nicely done roger, looks clean but also elegant
    Z
    /////Alpine CDA-9887 HU
    /////Alpine KTX-1000EQ
    /////Alpine PDX-4.150
    /////Alpine PDX-1.1000
    Polk Audio SR 6500
    Polk Audio SR 124 DVC
    KnuKonceptz MKS Kable
    G35
    /////Alpine SPX 17PRO
    /////Alpine SWX 1243D
  • Jstas
    Jstas Posts: 14,820
    Nice deal but are you OK with that amp sticking up like that?
    Seems like it would rattle around alot and vibration ain't good for components.
    Also, if you use that trunk, the amp is in a precarious spot.
    Nice work though. Clean and simple. I like it.
    Expert Moron Extraordinaire
  • ROOGER82
    ROOGER82 Posts: 30
    ya I did lots of measuring before I put the amp there...there is no room for it to sway side to side...its has a board under it holding it at an angle.
    I rarely use the trunk...and when i do there is nothing large in it.
    Well I ran into some problems. I cant get the damn subs to work. I dont have an aftermarket radio so im using and Audiocontrol LC6i.THe amps power on and everything. There is just nothing happeneing with the subs. Will have to take it all out and check it out.
    On the bright side Ill have more pics on the installation process.
  • black magic
    black magic Posts: 669
    Looks really good. I like the suede. Those look like the Mobile Monitor subs.
