Anyone with two PS3's in the house?
Sami
I finally got me a second one, and I was wondering what difficulties you have experienced setting them up? I would assume setting the BT controllers to control only one would be the first thing I need to do.
Post edited by Sami on
It appears that may be more trouble than it's worth. Go ahead and save yourself the headache and send one of 'em my way.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
Yes. If you set it up for both it may control both at the same time. I know that one day the kids moved the controllers and they were turning on the machine in the other room. If you have any questions fire away. Are you using a router? If so there is some potential headaches.Reciver Pre/Pro - H/K AVR-347
Amplifier - Adcom-7400 5 Channel
Speakers - SRT's
Projector - Sony Avl-aw15 -
I use two ps3 one in the living room and one in the basement HT. It is never an issue with me because I only have one on at a time and use them 99% of the time for BD
I use the same controllers and BT remote for both -
I doubt I'll use them for gaming that much at the same time, but who knows. Both on the same router. I have one in the HT which has its sources all shared with bedroom, and I got one for our family room as well. I like the ability to play all my videos and music (I figured out how to get FLAC working) through it, plus all DVD's and BD's as well.
It's not going to be a major problem in any case, just wanted to know what to expect. When playing, one can disable controls from the menu so the game servers should be the biggest issue, whether they can handle it. PC games have no problems but I've heard PS3 games do.
