In ear Noise Caneling Headphones
andrew_mac
andrew_mac Posts: 95
edited September 2008 in Electronics
Hey all.
Theses iPod headphones are crap. I'm looking for some advice on some "in ear noise canceling headphones." If have any experience with these your advice would be much appreciated. I guess my budget would be $100 could be more depending on advice. Thanks in advance.
Andrew
Front - RtiA5's
Surround - RtiA1's
Center - CsiA6
Sub - Velodyne DPS12
B&K Ref 50 Pre
Amp - B&K AV5000 II
Ben's Silver IC's
Post edited by andrew_mac on
  • carpenter
    carpenter Posts: 362
    I use Shure SE210.
    The noise cancellation works fine, and overall sound quality is good.
    The thing I like the most is that it's very sturdy.
    those things usually don't last with me, and this one proved it can take a lot of punishment.
    "If the global crisis continues, by the end of the year Only two Banks will be operational, the Blood Bank and the Sperm Bank. Then these 2 banks will merge and it will be called 'The Bloody **** Bank'"
