video interconnects (RCA video vs. RCA audio)
gidrah
I understand the difference between S-video, composite & component video interconnects.
My question is this: When using RCA interconnects for video, is there any difference when using a cable designated for video and one of equal quality that is designed for audio. Is this just marketing/packaging, or is there an honest difference between the two?
Make it Funky!
Post edited by gidrah on
...it depends on who you ask. If building the main HT system, I would certainly get a video-designated cable. Video works in a lot different frequencies than audio does. (duh) Thus, a cable desgned to carry higher frequencies and to shield interference fromthose frequencies.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
Right on there Wes, a video cable will offer a little more 'distance', and shielding between the two contained signals in the cable.
Some say if you are worried about getting best AUDIO interconnect, use a 'video' designated cable.....
Cheers,
Isn't the impedance different between an RCA audio and video cable? I know for a coax digital cable they say to only use a 75ohm cable. Since a video cable happens to be this, you can use one of those instead (since they're much cheaper). What's the impedance of an RCA audio cable?
Aaron -
"What's the impedance of an RCA audio cable?"
Analog audio cables are 50 ohm and should not be used for video or digital (S/PDIF) audio. -
