3.1 compared to 2.3
2-tall
2-tall Posts: 98
edited September 2008 in Vintage Speakers
Hi
I thinking about buying a set of 2.3 tl's.I presently have a set of 3.1 tl's with the rdo tweeters.I like the 3.1's but would like to know if any one here has had the chance to compare these speakers and could let me know what the results were.
Post edited by 2-tall on
  • engtaz
    engtaz Posts: 7,664
    More SDA effects on 2.3's.
    engtaz
    engtaz
  • Joe08867
    Joe08867 Posts: 3,919
    + 1 Lasareath. It's like apples an oranges. 2.3's all the way.
  • george daniel
    george daniel Posts: 12,096
    The 2.3tl's will just do it better in every way IMHO,, they just have a bigger presence--good luck.
  • stubby
    stubby Posts: 723
    How large is your room? If not very big, the 3.1's might work better for you. They have the most narrow front baffle and a single tweeter. This gives it exceptional depth in imaging. Mine also have the RDO's along with a hot-rodded X-over (sonicaps and mills). On most music it compares favorably to my 1.2's. 3.1's simply don't have the deep bass extension.
    stubby
    SRS 3.1TL
    Harman Kardon Citation 5.1
    Anthem AVM2
  • 2-tall
    2-tall Posts: 98
    My room is 12x22.I have a paradigm 2200 v2 sub.Did the caps and mills help that much?If so could you let me kow how that was done?
  • stubby
    stubby Posts: 723
    2-tall, your room looks almost identical to mine. I have mine set up on the long wall.
    As for the difference in sound before and after the x-over upgrade, I could not tell you. Ricardo did all the work! I do know that front to rear imaging is probably the best I have heard from an SDA. Width is very source dependant. I use CRS's and 1.2TL's for a reference. Oh, yeah, I also had a pair of 2B's. Anyhoo, brass instruments sound more real than I have heard from past SDA's. Really crisp. Vocals are also more intelligable. Subtle background sound is clearer. Things are just BETTER.
    Try doin' a search about "3.1TL crossover upgrade", I think you will find everything you need there.
    stubby
    SRS 3.1TL
    Anthem AVM2
  • 2-tall
    2-tall Posts: 98
