DIY Sub Enclosure
vfx
My audio guy recommended to make my own sub box. what are the pros and cons of doing so? What makes it different from buying a pre-cut one? Do you think it will make a huge difference in sound quality? BTW, what're the best sub enclosures you can buy?
Post edited by vfx on
it depends on alot of factors. Mainly the driver if you buy a pre cut you have to find a driver that matches those dimentions space wise , You can buy just about any driver and build your box to match what you need.:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
