RM3000 satellite specs
Chameleon2
Chameleon2 Posts: 112
edited October 2008 in Vintage Speakers
I found an old thread http://www.polkaudio.com/forums/showthread.php?t=1161&highlight=rm3000 which provided the specs for my RM1000W sub, but not the 3000's.
Anyone have these specs?
thanks
Post edited by Chameleon2 on
  • Motzart
    Motzart Posts: 1,075
    edited September 2008
    This might help?
    Yamaha RX-A710 90Watt 7.1
    Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
    Music CD: Sony CDP-CE375 5 Disk
    HD TV: Vizio 42" LCD 1080p E420VO
    Blu-Ray: Sony BDP-S350
    DVD: Sony DVP-NC665P 5 Disk
    AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
    Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
    Phones: Sennheiser HD280 Pro
  • Chameleon2
    awesome, thanks!
  • Chameleon2
    Followup question; what would make one of these speakers suddenly crap out?
    I've had them since new when I purchased them around 1994.
    The had been hooked up to their current configuration since early 2000.
    Went to play some CD's a week or 2 ago and the sound wasn't there; muted and no clarity at all.
    I verified it wasn't the receiver by switching with other speakers where the sound was normal.
    Any suggestions?
  • ben62670
    ben62670 Posts: 15,969
    When you swapped speakers did you use the same speaker wires for both? Also are the tweeters fine?
    Ben
  • Chameleon2
    Re-reading my post; to clarify, both RM3000's "went bad" at the same time.
    The speakers I used to check the front connection were the surround speakers.
    Speaker wires are the same since 1994. They are in excellent condition as far as I can tell (clean, no kinks, etc).
    The receiver is a Denon AVR 1500, 70 watts.
    Just reconnected the 3000's to the front, took the covers off and plain as day, there was nothing coming out of either 3-1/2 inch driver.
    All I can say is that I guess the sound from the tweeters is normal; it's so different from what I'm used to hearing from the speakers.
  • Chameleon2
    update: replacement drivers for the RM3000's are P/N RD5001-4 ($60 ea).
  • Jed Leland
    Jed Leland Posts: 183
    Hello,
    When you order let Polk know you're a CP member and you'll get them for $48.00 each and free shipping.
    Cheers, Jed
  • Chameleon2
  • Velo Steve
    Velo Steve Posts: 4
    edited October 2008
    A while back Motzart posted the front of the RM3000 spec sheet, which included specs for the RM1000W. Unfortunately, I need one thing more.
    I want to drive the sub with a single-channel subwoofer amp, but the typical RM1000W setup is for stereo inputs. I'm thinking that the 5th (blue) terminal on the subwoofer has something to do with doing mono input correctly. If anyone can describe what that terminal was for, or post a copy of the instructions, I'd be most thankful.
    By the way, my situation is that I'm planning to get a much bigger subwoofer early next year, but I already have the amp so I might as well use it.
  • Velo Steve
    Velo Steve Posts: 4
    edited October 2008
    Oops - I found the answer myself in this "sticky" thread:
    http://www.polkaudio.com/forums/showthread.php?t=38755
