Cab to accomodate Center speaker
xandra
frustrated at finding a cab that would hold all my ever-expanding stuff and still be mobile. finally decided to design my own.
for your amusement Here's the plan:
http://home.rochester.rr.com/alexleighs/AV/3WideLGv14-closelighter.jpg
might be bfuggly - but has space for CSi5...
LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
Post edited by xandra on
Very nice. I see you have the door open on your amp. That Parasound definitely wants to breath.
Ben -
Ben - both doors open. a real neccessity, But the amp was was blowing warm air at me thru my cpu's monitor - so I opened it for the rendering...
Actually - I'm pretty impressed at how cool the parasound runs (I've heard the Halo series runs considerably warmer)LR Setup:
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability. -
consider building extra space into the shelf opening(s) to place vibration pads, or some isolating material. Don't want your speakers vibrating the cabinetry.[
I can't remember off the top of my head, but you can sandwich tile,cork,tile,cork,tile to make a real cheap effective ISO pad. The tile I am talking about is the cheap peel and stick floor tiles. The cork you can get at a craft store.
Ben -
-Vonnie123consider building extra space into the shelf opening(s) to place vibration pads, or some isolating material
VONNIE: Are you talking here about where the shelves sit on shelf pins?
If not: where are you talking about?
If so: The best solution I've seen comes with BDI cabs. their pins are wrapped in some heavy duty rubber. further they're threaded inserts, which in itself avoids vibration. Lastly, the underside of shelves are routed with indents to prevent foward/backward sliding and hold shelf in place even firmer.(I'll be doing this)
(After spending weeks trying to find similar on the web, I gave up and called BDI, turns out these are proprietary items - made specifically for BDI, alas they would not sell me any in a decent quantity.) Personally I think they could make a fortune selling these.
BEN: I like the cork idea, as that could easily be glued. - had been looking into anti-vibration rubber (used to use in workshop - but scraps I've got left over way too thick)
My biggest concern's are ventilation, and cord routing.
The trickiest part of the cord routing is finding a way to keep RFcables, electrics away from everything else, yet still permit flexible routing.
As for ventilation: I'm actually considering holes thru the top (at the rear)
I've adapted some of BDI's techniques here, but not sure they're as ideal as I'd like.
I'll post another pic shortly which makes the contruction clearer and see if I can evoke any ideas.
Thanks all for your input and ideas, please keep'm coming.LR Setup:
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
Lazereth: for an open design unit - that's one very stable looking rack. Not something I can use tho (i need mobility). Still one of the nicest I've seen in that style.
Also like your ikea temp solution. I wish there were an ikea near me - great bang for the buck - and their the only furniture place I've seen with truly honest material descriptions. alas, their shipping rates seriously diminshes value.LR Setup:
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
LR Setup:
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
