epik sub placement
kweb
kweb Posts: 25
The system I'm running is rti6's for front's, csi5 for the center and tc60i's for the rear's. An epik valor 15'' sealed cabinet for the sub and the onkyo tx-sr600 reciever.
The problem is sub placement. The room is in the basement and it's a finished room, drywall and drop ceiling and carpet, 12' x36' with one standard size door opening.
I think i've had this sub all over the room and I'm not getting the thump I was expecting. However, upstairs it sound's like it would rip your head off if you went downstairs. The volume at about 3/4 on the reciever and1/2 on the sub [i'm not quit sure how hard you can drive this sub without damage]. There even seems to be spots where it doesn't even seem like the sub's on, but if you put your hand on the cabinet and it's pumping. The hook up I am using is LFE from the receiver to the sub.
Any input would be greatly appreciated Thank's Ken.
Post edited by kweb on
  • Ron Temple
    Ron Temple Posts: 3,212
    edited September 2008
    kweb wrote: »
    I take it you're on slab. The sub is not exciting the floor...takes alot more sub to do that. I'd try running some test tones of doing a REW graph to find out what's happening. Could be many things. Since it's a long or wide room depending on orientation, the LP might be smack in the depth of a null. It's not the sub, the Valor can get you to 109-111dbs average in most rooms.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • kweb
    kweb Posts: 25
    Yes it's a slab floor, but I'm not sure what you are talking about with the REW graphs. What are you referring to about the LP? I'm kind of new at this so...sorry,
    Thxs,
    Ken
  • millerman 3732
    millerman 3732 Posts: 1,488
    REW = Room EQ Wizard.
    It can be down loaded here.
    http://www.hometheatershack.com/forums/rew-forum/
    LP = Listening position.
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Toshiba HD-XA2 (HD-DVD, CD)
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi 10 (bi-amped)
    Polk CSi5 (bi-amped)
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
    TV Rig: Samsung 50'' 4k display
    Polk Signa-1 Surround bar
  • Early B.
    Early B. Posts: 7,900
    I agree with Ron. You don't have enough sub for your size room on a slab, especially since it's a sealed sub.
    My advice is to set it as close to your seating position as possible. Also, it would help if you invested in floorstanders with some decent bass to help out the sub.
    "God grooves with tubes."
