tweeter messed up ? got questions
Deadof_knight
OK at first I thought it was my amp then, after moving interconnects the problem stayed on the right , then I moved the tweeters (swapping all the lefts for the rights) now the issue is on the left so problem moved ok its the tweets, Im just having a hard time figuring out which one I can listen too them all put my ear up too them , turn the 6.5s off with my other amp. and have only tweeters playing. I hear music from all the tweeters, its just not crisp on this channel , Got any ideas maybe I should ohm each one out ? its kinda like the left side one or two of the tweets is muffled, its just not as crisp. any ideas will be appreciated
IDK
Dead
IDK
Dead
:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
Post edited by Deadof_knight on
Ohm all of the tweeters out both in circuit and out of circuit and provide the results please.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I don't think they're all supposed to sound the same. That's why I couldn't hang the same cap on all 4 in my srs's.
Use a paper towel tube over the tweet to isolate it from the others.
Ok Ive isolated them one at a time , they have a different sound each one I expected that. So I pulled them out and ohmed them, all were 5.5 except one 5.8 I pulled the 5.8 out of the line up and replaced it. Everything is back to normal Dont think .3 ohms is enough to make that much of a difference but ....here we are Im happy again for a little while...anyways.:cool: " He who dies with the most equipment wins Right ? "
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
great, how do the sl3000's sound?
don't forget to give me feedback
I thought I did that already but Ill check so far I like the sl300s Ive put in. They seem a little more crispin the ones that replaced , I put them in the tweeter location that was the loudest the 3rd one down from the top.:cool: " He who dies with the most equipment wins Right ? "
crisp is much better than dull
I left feedback for you but I don't see any from you. -
Ill get on it then thaks for the reminder sorry for the delay:cool: " He who dies with the most equipment wins Right ? "
