5-Channel Amp Question
sir_lagzalot
Right now I'm using two Sony amps running mono@300wpc for the fronts and an Onkyo 805 for the center, surrounds, and rears. My question is it better to buy a good 3-channel amp and run the fronts and center off of it and use the Sonys stereo@110wpc to run the surrounds and rears, or buy a good 5-channel amp to run the center, surrounds, and rears and leave the Sonys running the fronts.
****Home Theater****
Integra DHC-40.1
Rotel RMB-1075
Fronts 265-RT
Center 265-RT
Rears 65-RT
Sub BIC H-100
****VIDEO****
Projector Epson 8700 UB
BLU-RAY Sony BDP-S1000ES
****2-Channel****
Magnepan SMGa
Sub ED A3-250
AMC 3100a
TT Music Hall 2.2
Bellari VP 130 Phono Pre
Grant Fidelity Tube DAC-09
Sirius Stiletto 2
Integra DHC-40.1
Rotel RMB-1075
Fronts 265-RT
Center 265-RT
Rears 65-RT
Sub BIC H-100
****VIDEO****
****2-Channel****
Magnepan SMGa
Sub ED A3-250
AMC 3100a
TT Music Hall 2.2
Sirius Stiletto 2
Post edited by sir_lagzalot on
Buy a 7-channel amp. The difference in cost between a 5 vs. 7 channel amp is negligible and gives you more options. Buy an Emotiva UPA-7.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Thanks for the advice Early****Home Theater****
Integra DHC-40.1
Rotel RMB-1075
Fronts 265-RT
Center 265-RT
Rears 65-RT
Sub BIC H-100
****VIDEO****
****2-Channel****
Magnepan SMGa
Sub ED A3-250
AMC 3100a
TT Music Hall 2.2
Sirius Stiletto 2 -
I would definately recommend running all your speakers with the same amp, be it 5 or 7 channel. My HT solidified tremendously when I went from a 2 channel x 200 ADCOM powering the L&R and the receiver driving the rest to a 5 channel x 125w ADCOM GFA-7000.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
If I were you, I'd consider getting another sony TA-N330ES to run my center channel. I think those amps are awesome - they sound very good, drive almost anything, and seem to last forever. Your 805 has plenty of juice to run the surrounds.
To be honest though, I think you have more than enough amplification. I don't think you're going to get a significant improvement (if any). The TA-N330ES's can easily drive 2 RTi10s each. I know b/c I own 2. I've tried them bridged and in stereo and heard no difference on my RTi10's in a rather large room. I'm currently using them to drive some other speakers though. Perhaps consider soom room treatments or upgrading speakers if you are dissatisfied. I seriously think you'd be wasting money on more amps...your Sonys are awesome and the onkyo is one of the strongest receivers around. -
It's not an issue of having enough power with the Sony's. Any external amp is going to have higher quality power than the Oinker amp section. Adding a 5 channel amp will allow all 5 speakers to be driven by the same amp all with the same sound signature. I was perfectly happy with my GFA-555 and AVR setup, but once I added the GFA-7000 powering all 5 channels, the soundstage solidified and location in the room is now seamless. I can't directly tell which speaker sound is coming from easily. I actually stepped down in power from 200wpc to 125wpc and am happier with the performance of my HT.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
I have never been happier since I started using a five channel amp, up from a two. I feel the sound is more even thoughout the room. I debated over the power of the amp also. I elected to go with 200w Vs. 125w. Not sure if it would have made a big difference for me (room size and speaker quality), but I was afraid I would always wonder if I had gone with 125w.Anthem D2v
NAD M50 Music Server
B & K Reference 200.5
Parasound A21
B & W 804 (Mains)
B & W HTM1 (Center)
Polk Rti4 (Surrounds)
PS3
Seaton Submersive HP
Pioneer PDP 6010FD Kuro -
Welcome to Club Polk TG.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
